-   -   Chevy 1500 with 355 (http://www.hotrodders.com/forum/chevy-1500-355-a-230777.html)
jromo12 03-15-2013 09:50 PM
Chevy 1500 with 355
hello,
I have recently bored my 350 motor 30 over, and got my heads re- built ported and polished. I have after market exhaust and a cold air intake system already set up i also put a mild cam in after getting my motor re worked . Any ideas of what i could do to help boost up some power??? Thanks for any comments open to all suggestions!!
Not interested in nitrious !!
1991 chevy 1500 . tbi fuel injection.
MARTINSR 03-15-2013 10:18 PM
Post this question in the engine forum, this forum is for saying WELCOME! :welcome:
33Willys77 03-16-2013 05:10 AM
More compression, intake, carb/EFI, blower, more cam, etc. What do you have and what are you looking for?
poncho62 03-16-2013 07:10 AM
Put it in something lighter....and more aerodynamic
dually502 03-16-2013 09:17 AM
Well . U arent gonna get much more from that motor.. The heads are the limiting factor. The worst flowing heads GM ever made for a SBC..
My truck is a 1994 TBI 350..
I have absolutely nothing done to my truck except cold air intake and 3:73 gears.. My ext cab truck with gears outruns my friends .030 over 350 in his 92 reg cab truck. Gears really make a huge difference.
U got headers? What intake are u running?
U can get an aftermarket intake that still uses the EGR but its over $250. I would get a good used Edelbrock dual plane carb intake and TBI adapter. Then order a chip to tune out the EGR.
After that, its all going to be in modifying your throttle body. Its the choke..
Go to TBI CHIPS and go to the TBI mods page. There u will find all the info u need to get a lil more HP out of it with modifying the throttle body
My first choice would be gears..
ssmonty 03-16-2013 05:36 PM
If you don't have inspections, replace the catalytic convertor with a test pipe..
ssmonty
