chevy 1950 3/4 ton to 1/2 ton solid axle swap
want to put power discs on my 3/4ton truck but have been unable to find a front disc brake conversion kit which will allow me to keep my 8 lug rotors. have been advised that switching to a 1/2 ton front axle is fairly straight forward and will allow me to use widely available 5 or Six lug kits for the 1/2 ton truck.
would appreciate any advice on this swap especially from someone who has done it before. also any advice on where to track down a front axle? |
Scarebird is working on a kit for the 3/4 ton axle if you do not mind the 8 lug
hubs- otherwise the 2 axles use the same springs so its not a difficult swap. Look for someone doing a swap to independent front end- maybe a craigs list wanted. Jim |
i would prefer to keep the eight lug if i could but i havent been able to track down anyone with a tested and complete kit. scarebird hasnt followed up on my inquiries so my guess is he isnt ready to market. have you heard of any one who has another 3/4 ton kit out there?
the other dyi solutions i have seen unfortunately require fab skills and knowledge i aint got. this is my first so i am learning as i go. other than the axle what parts would i need to find in order to use the 1/2 ton kit? |
which parts ?
can you just swap out the 8 bolt hubs and use 6 bolt hubs ? I sometimes go to on line parts co's ...Napa, autozone and compare part numbers. see what parts are the same, king pins, bearings, seals, etc. also check out the stovebolt site
spindle swap ?
years ago I did olds spindles on a 40's ford axle, I had new bushings pressed into the spindles and had the local engine machine shop hone the bushings to fit the ford king pins, then had a truck shop do the bend the axle for alignment. 70's fords trucks use kingpins and 8 lug disc's.
Axle and spindle should do it, the draglink should be the same, springs are the same, watch for interference on the tie rods with whatever kit you use.Jim |
| 1950 chevy swap to s-10 frame | jason fitzloff | Hotrodding Basics | 6 | 03-10-2012 07:06 AM |
| 46 Chevy Solid Axle Power Steering | BOXER957 | Suspension - Brakes - Steering | 1 | 12-01-2008 03:37 PM |
| frame swap for 1950 chevy p/u | chevykid33 | Introduce Yourself | 2 | 08-13-2007 10:05 PM |
| rear end swap for 1950 chevy w/ 350 | blake | Transmission - Rearend | 2 | 10-10-2004 08:51 AM |
| 1950 chevy frame swap | trott | Hotrodders' Lounge | 2 | 12-23-2002 09:26 AM |
