chevy 1991 tbi wiring - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 02-25-2012, 10:20 AM
Hi, does the 1990 and 1991 chevy truck and car tbi engine have the same wiring digram. I have a 91 truck harness and computer, having problems incorporating the fuel canister purge motor,which go to a-3 on my computer no pins,on the speed sensor, are the two interchangable ? thanks.
Old 02-26-2012, 06:06 AM
LATECH's Avatar
Last journal entry: New Gas Tank
theyn should be pretty close if not the same. You will have to compare the 2 wiring diagrams for both to be sure.
There can be small differences, like connector design/shape/pin posisition.
a lot of times the connector can be dissasembled and the plastic part can be changed so the alternate style device can be connected to.
As long as you have both harnesses, you should be able to compare them ithout a wiring diagram, and any connector differences should be easy to remedy as you have all you need right there.Otherwise you will hav to make a parts run.
Old 03-02-2012, 06:13 PM
EagleMark's Avatar
GearHead-EFI.com
They are pretty much the same. The cars usually have IAT or MAT while the truck do not. ECMs usually plug in the same but could be the extra wires for this circut. What ECM nuber did the car have?
The 1990-91 truck uses a 1227747 ECM and all the wiring diagrams for it are here:
http://www.gearhead-efi.com/Fuel-Inj...Information-42
Recent Modern Electronic Engines posts with photos
1991 Chevy 305 Cam help Hawk78 Engine 1 02-17-2010 09:53 PM
1991 chevy 350 TBI wiring harness into streetrod RodFather Electrical 1 03-05-2008 11:10 AM
1991 chevy 350 scapegoat Engine 11 09-20-2007 09:02 AM
1991 chevy s-10 blazer swapindonnie Engine 5 11-27-2002 05:16 PM
1991 chevy 4wd V6 swap to V8 Michael Breaux Engine 3 10-20-2002 02:48 PM
