Chevy 283 - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 10-15-2006, 03:18 PM
poncho62's Avatar
Wiki Edits: 5
327 crank in a 283 block gives you a 307........
283 crank in a 327 block gives you a 302...........
  #32 (permalink)
Old 10-15-2006, 03:19 PM
"the 283 was a small journal,the 327 was made both in the small and large journal. By using the small journal 327 internals in the 283, you now have a stroked 302, excellent for high rpm at extended periods of time."
With respect, I have to say the above statement is incorrect...
A 283 bore(3.875") with a 327 stroke (3.25") yields a 307.
A 327 bore (4.00") with a 283 stroke (3.00") yeilds a 302. (or 301 as the hotrodders called them before Chevy brought out the 302)
JA
OOPS: poncho62 types faster than I do///
  #33 (permalink)
Old 10-15-2006, 03:55 PM
poncho62's Avatar
Wiki Edits: 5
But, you explained it better..........................
  #34 (permalink)
Old 10-15-2006, 06:02 PM
Malibu Nut
I was just saying bore out the 283 to 4 inches b/c I read in my 283 Hi Po book that the later block 63-67 will bore out to 4 inches when the early ones 57-62 will only bore safely out .060 due to already being bored from the earlier 265 blocks.
  #35 (permalink)
Old 10-16-2006, 07:52 AM
Originally Posted by 50 notchback
discrepency? what discrepency, after extensive track testing, over 12 1st place trophy's and 22 years building engines in west texas, i am pretty sure knowledge as well as experience beats guessing everyday.
I was just wondering why you said "there's no replacement for displacement" in one sentence then talk about your 283 "stroked" to a 302 beating larger displacement engines in the next paragraph. 43 years of engine building experience leads me to believe that sanctioning bodies limit engine displacement for a reason.
A 283 with a 327 crank is a 307. If you clean up the bore to 3.905, it's a 311. We use the 307 cranks to make 327's for road racing in early 60's Novas.
  #36 (permalink)
Old 10-16-2006, 02:41 PM
live to build
thats the way they were ihave one if you need parts
  #37 (permalink)
Old 07-31-2013, 01:59 PM
hi there. I have a 283 motor in my rebuild < this is the first of the v8 it has a press fit pulley ,u can drill and tap the crank . It also has a different mounting point ,they are futher forward
  #38 (permalink)
Old 07-31-2013, 02:24 PM
jokerZ71's Avatar
Wrench Turner
This thread is 7 years old. LOL. I've done it too.
WHat's a 283 good for? WHat kinda gas mileage? Your opinion needed! 54Guy Engine 18 11-21-2008 05:21 PM
chevy 283 rear main seal. Brother's57 Engine 4 01-23-2006 05:16 PM
base timing on a 66 chevy 283 powerglide_66 Engine 1 12-19-2003 05:14 PM
283 chevy block vent 70gs455 Engine 8 06-13-2003 02:28 PM
283 Chevy pad numbers 56don Engine 3 05-18-2003 11:20 PM
