Chevy 283 Build - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-25-2011, 12:37 AM
Chevy 283 Build
Hey everyone, looking in to building up the stock 283 i put in my 63 4dr nova last summer. Its a blast having it in there and the thing moves pretty good but i want more power. Id like to get about 300-350 hp out of it. Anyone got any suggestions to intake, cam, heads, etc? I mostly do street driving but i dont care about the mpgs. I plan on putting in a th350 with a descent stall and some low gears in the rear.
Old 12-25-2011, 05:12 AM
sedan delivery's Avatar
283 build
i'm from old school and like factory parts or reproduction of factory parts. such as cam shafts. the 327 back in 1967 so as a 350hp hyd cam shaft does very well on the street. if you like more radical the 365hp camshaft is a solid lifter cam shaft called the 30-30. the cubic of the engine may mot be correct but the cam shafts are correct, both were use in corvette and comaro. if you can find a chevrolet interchangable part book it will give specs. crane cams make a factory replacement parts cam shaft. use ing the power pack heads or the fuely heads are a good choice. look for around 64cc heads . there are other choices. manifold and carb. is a matter of choice. i like the performer and a quadrajet others like the holly . i sure you will get some other suggestions. the interchangable book can be found at barnes and noble book store also check Amazon.com
Old 12-25-2011, 08:47 AM
if you plan to make that much power with a 283 then you will need more gear, more stall converter, and more compression. 3000 stall and 4.11's would be a good idea.
If you don't want to change gears and converter, ect. then plan on using a bigger engine, like a 350, 383, or 400.
A compcam 280H with the correct valve springs. Will need about 10:1 compression and headers. 2-1/4 to 2-1/2 dual exhaust system.
I would use a performer or regular RPM intake (square bore) with a 600-750 holley square bore carb (vacuum secondary).
Or add some boost to the 283. (turbo, blower, super charger, or n02) and leave the rest of the car alone.
Old 12-25-2011, 09:01 AM
Chevy 283
I've been noticing that on a couple forums that guys really like the 350hp 327 cam and running 305 heads on there. But i also heard those heads have a tendancy to warp. Not sure if its true or not. I definetly plan on putting a stall and new gears also. I want to keep the 283 but im just having a harder time figuring out a good power combo because alot of people seem to have different opinions on this motor. Any more suggestions would be great, thanks.
Old 12-25-2011, 09:11 AM
DoubleVision's Avatar
Getting the 283 to 300 horses isn`t a easy task without killing the low end torque. Bolting on 305 heads isn`t going to get it there either. Flow is power, and the heads are the key to making high power numbers. The problem with the 283 is while it`s a great small block, it`s small cubic inches, the bores not very large and the stroke is short. If you tried to follow the pattern of a classic small block with given power numbers such as trying to copy a L79 327 camshaft you`ll knock the wind out of that 283 and it`ll be a dog on take off. There are cams out there now that are so much more advanced than the old chevy cams will ever be. You also have to consider, a 327 has 44 cubic inches on a 283 and that`s alot which is why larger small blocks can handle larger cams. I would find a set of Vortec heads then select a cam that will keep you in the ball park of good low end torque. Install a good intake, carb, ignition, headers then tune it and you`ll have your 300 horses.
You may want to consider installing better rods or at least installing better rod bolts as the small journal rods aren`t very good.
Old 12-25-2011, 03:35 PM
283 build
you might look into a book by Smokey Yunick called power secrets by Smokey Yunick sold on Amazon.com. over 400hp from a 302ci using factory parts. he built a lot of small block chevys. high hp. check it out.you dont need big cubic inches to produce hp. i took a 1959 283 out to 301. 4 inch bore and 3 inch stroke . they do run and very well. used most of Smokey's secrets.good luck in your research..
Chevy BB 402 build up firebirder Engine 5 04-20-2011 10:33 PM
302 chevy build Jeepracer427 Engine 23 07-07-2010 03:57 PM
chevy 545 build the_1_gearhead Engine 5 08-28-2008 04:25 PM
Build me a 350 Chevy JAKE 68 GMC Engine 8 11-01-2006 08:12 PM
350 chevy build up ChevyTruckGuy Hotrodders' Lounge 8 10-18-2006 12:43 PM
