Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy 283 intermittently runs well
Old 08-06-2009, 03:02 PM
tgx's Avatar
tgx tgx is offline
Originally Posted by lg1969
I would check the fuel pressure regulator. It could give you problem. The electric fuel pump could be intermittent.
Well I added the pressure regulator after seeing the fuel filter empty intermittently so I figured if I added the regulator it would create a steady stream of fuel. That hasn't happened so it must be not receiving a steady amount.
I have replaced the fuel pump with a second electric one I had sitting around. Both of the pumps I have tried however are probably at least 8-10 years old now and are just these el cheapo jobs.
It may be that these simply can't flow enough fuel to keep up.
I think I will also check for a voltage drop and see if the circuit the pump is wired into isn't causing some sort of drop in flow rate.
