Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy 283 intermittently runs well
Old 08-09-2009, 04:37 PM
lg1969's Avatar
lg1969 lg1969 is offline
Google "Tunnel Ram 406"
I'm not to sure about stumble and die. Does it stumble the instant you are applying the gas pedal or just cruising at a steady speed? I would check the float Level in the carb. It may be set to high or check if the float valve if it's closing properly.
