chevy 292 flywheel ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2012, 01:04 PM
Can 292 flywheel fit small block? And dose 292 tranny fit small block? thanks
Old 12-08-2012, 02:16 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
It's been awhile, but IIRC the cast crank 292 flywheel uses 1/2" bolts to hold it onto the crank. So if you were to use a V8 flywheel, you'd need to drill it out for the 1/2" fasteners. I think- pls. double check this.
The tranny bolt pattern has to be the same as whatever bellhousing you use. There are at least two bearing retainer hole sizes (again, IIRC), so see what hole size and pattern that your tranny needs and use the appropriate bellhouse to match it. There are bellhousings that will fit but would be too small for the large truck flywheel, too. So the diameter of the flywheel also matters.
Some info on Chevy bellhousings can be seen here.
The Following 2 Users Say Thank You to cobalt327 For This Useful Post:
fordss (12-08-2012), painted jester (12-08-2012)
Old 12-08-2012, 02:21 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
The 292 fly wheel bolt holes are the wrong size ! The 292 isn't like other Chevy sixes, most of them used 1/2" flywheel bolts (instead of 7/16") and three dowels. As for what small block it depends on weather it internally balanced or external even if its adaptable. The starter must also match the diameter of the fly wheel.
Yes,the 292 has the same bell housing bolt pattern as all later Chevy v8s,small & big blocks.
Jester
Cobalt and I just posted together LOLI was hoping Id be first LOL
The Following 2 Users Say Thank You to painted jester For This Useful Post:
cobalt327 (12-08-2012), fordss (12-08-2012)
Old 12-08-2012, 02:29 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
IMHO more info is better than less, any way you look at it! Clarifying the engine to bellhouse bolt pattern is the same helps, too.
Old 12-08-2012, 02:57 PM
thanks u all
Old 12-08-2012, 03:15 PM
Your very welcome
Merry Christmas and good luck
292 chevy l6 QParker Engine 22 05-03-2013 02:37 AM
chevy l6 292 hp? fordss Engine 20 10-22-2012 09:25 AM
Chevy 292 L6 help CHEVILLAC Engine 3 07-09-2011 11:21 PM
292 chevy I6 QParker Transmission - Rearend 18 07-19-2010 09:57 AM
chevy 292 topdek Engine 1 01-04-2003 06:17 PM
