chevy 292 head tq down - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2012, 03:22 AM
Hi just put the head on and tq it down to 95 lbs. So do I tq it again After some mile ? Thanks
Old 12-07-2012, 04:19 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Some guys do, some don't. I have done it both ways and had no problems either way.
Steel shim gaskets are less likely to need a retorque than a thick composite gasket. When in doubt you can always ask the manufacturer for their recommendations.
If you decide you want to retorque, here is some info.
Be sure to use sealant on the threads of bolts entering the water jacket and a little motor oil under the head of the bolt. I always use a non hardening sealer. It's also a good idea to not torque the bolt on a painted surface unless the coat is very thin.
The Following User Says Thank You to cobalt327 For This Useful Post:
fordss (12-07-2012)
Old 12-07-2012, 05:56 AM
hcompton's Avatar
Old & Furious
Yes it is normally in the torque proceedure to put the car thru a heat cool cycle and re-tq the bolts. just a check to make sure they are holding firm.
Old 12-07-2012, 11:47 AM
O **** did not do any of that so what should I do now the book did not say any thing Like that
Old 12-07-2012, 09:14 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Remove the head bolts one at a time, put sealer on them and retorque to 95 ft/lb. Follow the tightening sequence below.
I use Permatex p/n 80019 Aviation Form-A-Gasket No. 3 Sealant, comes in a small bottle w/an attached brush. Costs $3-$4. Permatex #2 that comes in a tube is OK, too. Other guys use teflon sealers, etc. and report good results.
fordss (12-07-2012)
Old 12-07-2012, 10:48 PM
Thanks for u guys help
292 chevy l6 QParker Engine 22 05-03-2013 01:37 AM
292 Chevy 12 port Head QParker Engine 0 06-29-2010 01:51 AM
bbc head casting number 292 68c10owner Engine 3 04-27-2004 12:10 AM
292 Turbo Head sb72elcamino350 Engine 3 12-11-2003 11:29 PM
292 Chevy 69GMC Engine 3 02-13-2003 06:41 PM
