Chevy 292 with HEI - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2010, 12:11 PM
Chevy 292 with HEI
I'm working on a '74 Chevy inline 292 and i'm going to install a HEI distributor. I need to know what plugs to use and what the gap should be. The head uses the older style plug with gasket. Thanks
Old 01-13-2010, 02:05 PM
sqzbox's Avatar
My pipes are my music
Use the same heat range as you did with the points. The air fuel ratio hasn't changed, just the distributor. You will need a set of 8.5 mm plug cables with the HEI. I would gap them about 40K. Try that and if they don't run well go back to 35K.
Old 01-13-2010, 02:22 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Same plugs, .040" to .045" gap,
HEI Distributor in 55 Chevy paishman Engine 11 01-24-2006 10:44 AM
292 Chevy Inline 6 69GMC Engine 6 02-16-2003 10:31 AM
292 Chevy 69GMC Engine 3 02-13-2003 06:41 PM
chevy 292 topdek Engine 1 01-04-2003 05:17 PM
Chevy 292 in line 6 57Townsman210 Engine 2 01-03-2003 04:48 AM
