Chevy 292 inline 6 oil pan - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2010, 10:53 AM
I'm working on a Chevy 292 engine and I don't have an oil pan specifically for a 292. I do have a 250 pan which bolts up ok and clears the oil pickup, crank and rods. According to Leo Santucci in the "Chevrolet Inline Six Cylinder Power Manual" the 292 pan is deeper in the front and keeps the oil away from the spinning crank assembly. Has anyone used a 250 pan on a 292 for street use or know where I can get a 292 pan? Thanks.
Old 03-01-2010, 12:09 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
No help on the pan, but I bookmarked this some time ago.
HERE'S a 250 turbo build, but w/a BUNCH of good links to other parts manufacturers, etc.
Good luck.
Old 03-01-2010, 12:14 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
Here's one from a truck on e-bay for $50.
Rich
http://cgi.ebay.com/ebaymotors/ws/eB...d=400095447770
Old 03-01-2010, 02:19 PM
sprecher48's Avatar
Oddo nut
Last wiki edit: VW engine basics
Last journal entry: more,more,more
Location: sunny south(maybe rainy,haven't looked outside today) florida
Wiki Edits: 10
re;292 oilpan
check the boneyards,this was a common engine in late 60's early 70's commercial vehicles,such as panel trucks,small flatbeds,etc. the yards should be crawling with them. tom
Old 10-09-2010, 09:01 AM
Onefunponcho's Avatar
Easy to find
The 292 is very plentiful in many bone yards. You should be able to find one for a song. Id go that way then you know it will work.
Old 12-26-2010, 10:15 AM
I don't know about the oil pan. Can't help you there. Sorry. I bought a 292 for my 1950 Chevy Deluxe. I know nothing about this engine & have a hard time finding info on the web. Do you have any info you can send me? Or any websites you can forward?
Appreciate your help. Thanks
Dawn
Old 12-27-2010, 06:01 PM
sprecher48's Avatar
Oddo nut
Wiki Edits: 10
re;292 chevy
if i'm not incorrect;the 292 uses the same block as the 250. research the oil pans for the 250 and you should find one to suit your needs. tom
Old 12-27-2010, 11:05 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
IIRC the 292 has a taller deck than the 250, along about 1-3/4" difference. There are differences in the motor mount locations, the lifter cover is taller on the 292, but the heads are similar and at a glance they do resemble each other. The 292 uses a big coolant bypass hose off of the water neck- that's probably the easiest way to tell them apart at a glance/distance.
Old 03-15-2011, 12:57 AM
HotRod Hoodlum's Avatar
the Chevy 292 inline 6 oil pan is best set for the depth of the oil pump ,and the oil pump pick up tube.
you could use a 250 oil pan, but, you would have to the whole bottom of it off, and make the side walls taller, and then weld the bottom back on, to accommodate the 292 oil pump & tube.
trust me on this, just because that 250 pan bolts right up, doesnt mean, its gonna work
Old 03-15-2011, 01:01 AM
hiya BadKatLuck
Dawn
I too have a '50 chev, and I installed the 292 inline 6 , myself, I hope, you found some good info at Inliners.org.
you can always ask me stuff, also, good luck.
Old 03-15-2011, 02:11 AM
Correction to my reply
you could use a 250 oil pan, but, you would have to CUT the whole bottom of it off, and make the side walls taller, and then weld the bottom back on, to accommodate the 292 oil pump & pick up tube.
Above is the corrected answer I intended to answer / reply with. thanx.
350 Chevy oil pan leaking gasket Ed Baltera Engine 14 08-05-2012 01:17 PM
SBF Oil Pan Gasket Problems coda618 Engine 12 04-14-2010 05:11 PM
moroso oil filter sapsz28 Engine 10 05-09-2009 02:08 AM
Best oil pan sealant? mrdreex Engine 19 02-08-2009 12:09 AM
Oil Priming - Chevy V8 - No Oil to Lifter Bores - Help leejoy Engine 4 03-09-2008 10:55 PM
