292 L6 engine help
I work on those all the time. Strong blocks, good cooling of the block and generous oiling too. My suggestion is to consider three things.
1. Improve the intake and exhaust flows by adding exhaust headers and a multiple carburetor setup using a heated manifold. I think the Cast Iron headers give the best overall long term service and they can be purchased from a number of reputable vendors. 2. Think about an improved ignition/spark system and use a reputable HEI system. Include 8.5 mm HEI specialty wires too. Cams cane be costly so think about using a High Lift Rocker Arm assembly. I suggest 1.62 lift and I would talk to a vendor who does fantastic work at reasonable prices in Anderson, CA. Their website address is: www.rockerarms.com. 3. Use the "Lump Port" system for the intake and exhaust ports of your head advertised on the www.inliners.org site by a shop which advertises on that site. You won't be top contender but that thing should run smooth and do so at a reasonable prices. Normbc9 |
I'm not very well versed on the 292 in particular, but I can't imagine it'd be easy to get any 300-ish cubic inch engine to make that much torque with 300hp without some form of forced induction.
Like Carl Sagan said though, "but I could be wrong" |
Chevy 292 L6 help
I stop at Self racing in Durant, OK every year when I take my alcohol car on a Drag Strip tour. Here is his newest project engine. It is a Chevy 4200 six highly modified and cranking out over 500 HP on an engine Dyno on Racing Gas.
Normbc9 |
| 153 tooth Chevy flywheel in an original '55 Chevy 3 speed stick. | Classic Chevy Dave | Engine | 2 | 09-17-2010 03:44 PM |
| Putting a 72' chevy 350 into 1995 chevy silverado that has a 4l80e trans | Willbee26 | Transmission - Rearend | 3 | 03-28-2010 10:40 PM |
| chevy camaro vs chevy pickup bolt pattern | old fords | Transmission - Rearend | 2 | 09-19-2008 06:07 PM |
| Can you use a 1933 or 1935 Chevy transmission in a 1934 Chevy? | mistermuscles | Transmission - Rearend | 0 | 07-18-2004 05:40 PM |
| 1986 305 chevy vs. 1987 305 chevy new style small block | mtinsley | Engine | 2 | 08-22-2003 11:55 AM |
