Chevy 292 rochester carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2012, 10:47 PM
In my race club we run 250 6 cylinders they are bored out to 4 inch with small block chevy pistons crowder rods roller rockers solid cam and our club rule is a one barrel carb 292 rochester any one know how to get more air flow we can drill out jets but also need air flow to match thanks the jet
Old 10-19-2012, 09:18 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
In the olden days, this was always a point of contention with the tech inspectors.
Be careful introducing extra air (I call it 'bypass' air) through the intake manifold, like by opening up a vacuum port used for power brakes, for instance. This will make some cylinders run leaner than others- possibly to the point of damaging the engine.
If at all possible, be sure to introduce the air as close to the carb as you can, else you may run a cylinder(s) lean. You can also use individual orifices located in each cylinder's runner to equalize the air going into the engine and jet it up to compensate. This will work OK but it's better to add air closer to the carb so the air mixes better w/the fuel before entering the combustion chamber.
One thing that was done when this was hidden was to use hollow idle mixture screws. In some cases the entire idle circuit was reworked, even to the point where larger idle screws were made so a bigger hole could be drilled in them.
Hollow carb studs are another pathway. Now, if this isn't something that has to be hidden from view, you can use a spacer w/holes, slotted gaskets, etc. But the idea is to keep the extra air close to the carb if possible.
Old 10-19-2012, 11:02 AM
vinniekq2's Avatar
If allowed,machine the butterfly as thin as possible,smooth the screws that mount the blade and throttle shaft.Port it if allowed,trim and smooth airhorn,use a split duration cam with more time on the "intake" side.Change intake manifold if allowed,carb spacer.dedicated cold air package with inlet in front of car.
Carb help for Chevy 292 (six cyl) Chevy Mitch Engine 26 11-27-2011 10:06 PM
292 chevy carb QParker Engine 7 04-16-2010 04:53 PM
rochester carb HELP! grafter Engine 13 01-26-2008 07:07 PM
Rochester carb ID? fat50 Engine 3 06-13-2003 06:22 PM
ROCHESTER 2G CARB. DRIFTER Engine 7 04-19-2002 05:57 AM
