chevy 292 rocker adjustedment - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2012, 11:45 PM
How do u do it none hitech way . It runs but pops little at idle good higher rpm after head gasket replace. Thanks
Old 12-10-2012, 02:00 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Using a ratchet and deep socket with the motor warmed up and idling and valve cover removed, back off the adjusting nut on one rocker at a time until it clatters. Tighten down until the noise is gone, the put another half turn (180 degrees) on the nut. That's your lifter pre-load. Go to the next rocker. Yes, it's messy.
The Following User Says Thank You to techinspector1 For This Useful Post:
fordss (12-10-2012)
292 chevy l6 QParker Engine 22 05-03-2013 01:37 AM
chevy l6 292 hp? fordss Engine 20 10-22-2012 08:25 AM
Chevy 292 L6 help CHEVILLAC Engine 3 07-09-2011 10:21 PM
Need help with 292 rocker arm/valve stem clearance spec. fordy292 Engine 2 09-14-2004 03:40 AM
chevy 292 topdek Engine 1 01-04-2003 05:17 PM
