Chevy 3.4L V6 coolant issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2010, 09:21 PM
Hi guys,
I could need some advice.
A friend of mine has a 2005 Chevy Equinox. A couple days ago it started overheating. Coolant level was low. He topped it of but it overheated again shortly after. Right coolant low again. He brought it into a shop to diagnose the issue. They told him most likely the head gasket. I will get the car tomorrow to change the head gasket. Now I was reading a bit about that type of engine and the intake gasket and intake itself seem to pop up a lot as cause of this coolant issue. I will check the engine oil when I have the car. Any other save way to tell intake or head gasket? I hate to tear the heads down to find out thats not the problem. If its the head gasket anything specific to watch while I change it? Besides the usual machine the heads for flatness new head bolts...?
Any help is greatly appreciated!
Tomi
Old 04-27-2010, 11:19 PM
sqzbox's Avatar
My pipes are my music
I would suspect the intake before the heads. GM v-6's are known for leaking intakes. Anyway, the intake will come off first.
Before I would order any parts or start tearing the engine down, I would do my own diagnosis rather than rely on someone else's. JMHO! good luck!
Old 04-28-2010, 05:32 AM
BOBCRMAN@aol.com's Avatar
If you remove the heads. You will have to have them resurfaced. I do MANY of these. The heads will be warped .003-.006" ALWAYS. One overheat and the heads are warped. DO BOTH HEADS. Always replace the head bolts. Usually there are two+ exhaust studs broken off in the heads. At times I do six pairs of these per day. We have a special on these . Pressure check&mill. Thank god for generous motors 3.1-3.4 motors.
Old 04-28-2010, 09:09 PM
dklong's Avatar
pressure test the cooling system,you'll probably notice that the cylinder head next too the fire wall will be leaking coolant (the leak will be on the side next to the pass side , in the center of the head )
I had 2 of these last fall , both 2005 equinox , 3.4 l engine, with about 70 000 to 75000 miles on them.
the gasket had a crack in it, around a coolant passage,on both 2005 equinox it just looked like someone took a knife and cut the gasket !
Old 04-28-2010, 09:18 PM
T-bucket23's Avatar
Wiki Edits: 26
This is a huge issue with this particular engine. GM had these produced in China and did a lot of these under warranty. If it leaks internally they were covering them past the normal warranty period. you may want to check with the dealer.
The problem also usually comes back after the repair. As mentioned above, make sure the heads are resurfaced.
Chet
Old 04-28-2010, 10:58 PM
Thanks for all of your answers.
I finally go the car in. The coolant disappears thru the exhaust it makes a lot of white smoke. Its not leaking out anywhere and the oil doesnt show any signs of antifreeze contamination. Tomorrow I start taking it apart. I will keep you posted. Thanks for the help guys!
Tomi
Old 04-28-2010, 11:52 PM
sqzbox's Avatar
GM has a service bulletin on this subject "repair after damage" such as after over heating and coolant loss on the 05 equinox, 3.4 engine.
I didn't read the actual bulletin, but it's listed along with other re-calls for that year and model.
Read the list yesterday after a google search. If you search a little deeper, you might do better than me and be able to check the bulletin out or, check with the dealer on the subject as stated above. The service bulletins have all the info you will need.
Old 04-29-2010, 05:15 PM
Guess Im too stupid to find the detailed service bulletin. I was able to find a million and five of those but just for what car and the headline. No detail tho. However I go step by step now. Maybe I can stop already after the intake.
Thanks again for all the help!
Tomi
Old 04-29-2010, 08:40 PM
sqzbox's Avatar
That makes two of us! Maybe it's just not available on line. I'll bet Techinspector could cough it up in about two minutes.
He's slick like that.
Old 04-29-2010, 08:51 PM
sqzbox's Avatar
I posted a new Q on this same forum "GM service bulletin". Subscribe to the thread and maybe we'll get lucky with a response. Hope this helps with the bulletin search.
Old 04-30-2010, 06:19 AM
fast68's Avatar
likes chevy trucks & boobies
the gm 3.4L commonly blow head gaskets all the time, ive had to replace many for ppl i just did a grand am gt one recently
the old late 80's grand am 3.0L v6 head gaskets were bad like this also back in the day when they were common,
they are aluminum head engines and the factory gaskets werent good enough
Old 05-01-2010, 08:06 PM
So it is the head gasket. Intake was all nice and dandy. Cylinder 1 the gasket was oval and let the water in. Got it all out and take the heads to a machine shop Monday. Still have some cleaning to do. But it went pretty good.
Tomi
Old 02-19-2015, 05:19 AM
05 Equinox Overheating Issues
Hate to say this but was a blown head gasket on mine. I'm finding that this model is well known for it. Mine was overheating, especially when I stop. Never a sign of fluid leakage. Water pump as well as thermostat seemed to work just fine. I got it out of the shop yesterday $2,116
If any hears of a service bulletin addressing this issue please adive. Thanks
Old 02-19-2015, 09:03 AM
These vehicles were built about 10 minutes from me at the CAMI plant, I used to work there. These are Canadian made vehicles, but the engines were built in China and imported.
One of my jobs was bolting down the intake manifold on the engine.
peace
Hog
Old 02-19-2015, 01:51 PM
T-bucket23's Avatar
Wiki Edits: 26
5 year old thread boys
Chet
02 chevy 1500 4x4 v6 to v8 swap mike1975hd Introduce Yourself 2 10-15-2008 10:02 PM
chevy 4.3l v6 power cuervo_1979 Engine 1 06-13-2007 07:54 PM
1991 chevy 4wd V6 swap to V8 Michael Breaux Engine 3 10-20-2002 02:48 PM
Chevy 4.3L V6 to 350 swap pitsen3 Engine 2 03-16-2002 09:22 AM
pontiac V6 to chevy V8 swap snake Engine 2 01-20-2002 03:58 PM
