O/ D parts
Overdrive solenoids are pricy today, If yours doesn't work you can pull it apart and check the wireing connections, I usually see damaged wiring right at the grommet. and check out the contact points, they can be carefully filed like doing an old voltage regulator, At one time I made a manual shift lever to operate the pawl, when I couldn't find a good solenoid.
