Chevy 3-speed overdrive - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2013, 08:30 AM
A buddy has picked up one of these and wants to put it in his 64 Chev pickup. It has a lever and some sort of electrical connection that are involved with the overdrive. I havent seen it yet so dont know the specifics.
Anyone know of a good web source of info on these things?
Old 02-05-2013, 10:22 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If it's a B-W unit, here is a little info on it.
The Following User Says Thank You to cobalt327 For This Useful Post:
lmsport (02-07-2013)
Old 02-06-2013, 03:13 PM
Its probably an R-10 OD unit. The big ford motors used the R-11. R-7s were the late 40s, early 50s versions. Very good streeter trans. I dont have any of the OD parts, but if he needs 'soft' parts for the gearbox; I've got some left, just PM me.
Thats actually the better of the OD designs, over the Gear Vendors 'Laycock' design
The Following User Says Thank You to AutoGear For This Useful Post:
Old 02-06-2013, 05:13 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Need to figure out if its 6 or 12 v, I would imagine.
Old 02-07-2013, 06:59 AM
I got a look at it and appears to be a Saginaw three speed trans main case. The governor is broke but the solenoid is intact but functionality is unknown.
Thanks for the helps.
Old 02-10-2013, 04:25 PM
reed0380's Avatar
Dave Reed
chevy 3-speed O/D
All of the Chevy 3-speed transmissions with the 4-bolt side covers are actually Muncie transmissions produced from 1940 to 1965.
Old 02-14-2013, 09:20 PM
The first of the Chevy 3 speed OD transmissions came out in 1955 and it was a 12 volt car. Pontiac and the Chevy 3100 and GMC 100 series trucks were using the same transmission. There were four different gear combinations in them and the OD unit gave a 24% step up in output. Parts are available even today.
Normbc9
Old 02-15-2013, 08:01 AM
Wiki Edits: 27
O/ D parts
Overdrive solenoids are pricy today, If yours doesn't work you can pull it apart and check the wireing connections, I usually see damaged wiring right at the grommet. and check out the contact points, they can be carefully filed like doing an old voltage regulator, At one time I made a manual shift lever to operate the pawl, when I couldn't find a good solenoid.
'56 Ford three speed with overdrive Sgt RedMan Transmission - Rearend 6 04-07-2012 11:42 AM
Standard 3 speed with overdrive Footstomper Transmission - Rearend 0 06-03-2011 12:56 PM
1957 three speed Overdrive tsuadivad Transmission - Rearend 1 06-27-2009 09:14 PM
Chevy Nova 3 speed overdrive strummin67 Transmission - Rearend 7 11-30-2006 12:59 AM
3 speed w/overdrive for my flathead mercflathead Transmission - Rearend 7 03-25-2005 07:29 AM
