Chevy 305 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2004, 05:31 AM
Chevy 305
WANTING TO SWAP OUT MY QUADAJET TO A HOLLEY ON MY 87 EL CAMINO. PRESENT CARB IS COMPUTER CONTROLED? NEW HOLLEY ISN'T HOW DO I MAKE THIS SWAP?
Old 08-03-2004, 06:37 AM
DoubleVision's Avatar
If your intake is a factory intake, I wouldn`t bother swapping them, I`d just get the Q-jet rebuilt, you`ll gain no power by swapping to a Holley, and you`ll need a adapter plate which will cost you power instead of gaining it. Loose the caps, no need to shout.
Old 08-03-2004, 06:41 AM
stepside454's Avatar
double is correct, youll gain nothing with the Holley. & STOP YELLING
Old 08-03-2004, 09:55 AM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
Q jets are pretty cool carbs, and hard to get in decent shape anymore. Keep it and run it.
K
Old 08-03-2004, 10:58 AM
sorry about the caps key guys. just kinda learnin this stuff. as to the carb swap quad is pretty well toast. already have an aluminum intake and a spread bore adapter. holley has just been rebuilt. my problem is not knowing how this swap would effect computer?
Old 08-04-2004, 06:34 PM
Ghetto Jet's Avatar
pic of my Cobra should be here
Last journal entry: Lets Get Started With the Improvements
If you want to switch from a computer controlled carb to a non you will also need to swap out the distributor also, the factory one has parts controlled by the same computer that controls your carb and your car won't run right when you change just one of the two. Even if you don't gain much power your engine bay will look better with less of the computer crap in the way.
By the way that computer is located behind the passenger side kick panel.
Old 09-18-2004, 10:06 PM
computer qjets suck. you have no idea the time i spent jacking with my q jet. as soon as i replaced it with an old qjet and old distributor i saw not only more hp but better gas mileage to. go with the old stuff
as for the computer it will turn your check engine light on all the time qjet or holly. disregard the light
