Are the 2 cylinders side by side?....if so, I would guess a bad head gasket.
Does it seem to have a miss?
Ontario Rodders |
no, they are on oppisite sides of the block. No water or coolant in oil.
I think it was cyl. number 6 and 7. Also got a 305 I just might pick up for $25.00 with 120,000 miles on it. I just dont want to drive 120 miles to pick it up I think my isuzu has had enough abuse.
It is probably bad rings as well as the valve guides. Don't assume that rebuilding the heads will fix the problem. I almost guarantee the compression will still be low after a head rebuild.
Whew, 212,000 miles? I think I'd bend over and kiss that motor and send it to small block Heaven! You be on borrowed time my friend. Timing chain was stretched too far by 100,000 miles,valve/seats/guides gone about 25,000-75,000 miles further,bearing and cam getting "thin"....treat it like a girlfriend that got really fat....walk away on good terms.
haha well put
I know the car seems to need some work, but I for what you bought the thing for, its worth it. If that car has a strait body, throw a shift kit in the tranny, build a 350 (or better yet a 383 or 400) for it and do the little stuff that it needs!
Forget the 305, if you want one really bad you can buy mine off me! Its got a bigger cam, later heads, a bigger cam and a nice intake! K |
