chevy 305,can it be fast? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2007, 10:52 PM
I have an 81 elcamino that has a V8, 305.Does anyone have any ideas on how i can make some more horsepower without adding a supercharger or nitrous?
Old 03-05-2007, 11:01 PM
Gokussj5okazu's Avatar
Last journal entry: 336 Stroker: Teardown
Welcome to Hotrodders, Burnout
A good cam and better flowing exhaust will definitely wake it up some, depending on how it's built now. I assume it's stock?
To get a lot out of a 305 you either have to throw alot of money at it (metaphoricly ) or do something clever, like a stroker build on it.
Old 03-05-2007, 11:22 PM
2 words, stroke it
Old 03-05-2007, 11:33 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
one 305 mod info
more tips on 305 mods..joe
Old 03-06-2007, 03:13 AM
Guy Hiltz's Avatar
chevy 305,can it be fast ?
There was a very interesting article in the latest issue of Engine Masters,they took an older stock 305,put on a set of heads,a cam,intake and new carb and got 372 HP.I forget what heads they used,but the numbers were certainly impressive.They didnt touch the bottom end.
Old 03-06-2007, 05:17 AM
Hippie's Avatar
Last journal entry: HEI comparison.
Don't know about "fast" but they can be made to run pretty good, they do seem to like cams with a little tighter LSA than a 350. What exactly are your goals? I know a 305 HO with a 200-4R and a set of 3.73 gears in a G-body is pretty responsive, maybe not what most people consider "fast" but it will make people turn around and look when you stab the go pedal and makes stop light to stoplight driving more fun. It would definitely put your driving priviledges in peril.
Old 03-06-2007, 06:06 AM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Guy Hiltz, I think this might be the article you were thinking of?
http://www.popularhotrodding.com/eng...cks/index.html
BURNOUT, don't let anybody tell you you can't hot rod a 305...
Old 03-06-2007, 11:59 AM
Originally Posted by F-BIRD'88
What are you willing to do to get more power?
A 305 responds to moda just like any other SBC.
Your 305 is a low perf base engine. with low compression small heads and valves and tiny tiny camshaft and real bad exhaust manifolds. All this needs to be changed.
A hot rodded 305 will need a high(er) stall converter and a higher rear gear ratio than a simular hopped up 350.
The torque bnd gets shifted much higher in a 305 or any small ci motor when modded.
EG: the Monte Carlo SS 305 motor came with a special 3000 stall lockup converter and 3.73's.
To start with pull off one valve cover and get the cylinder head csting number off your heads.
Yes you can make your 305 fast. How fast do you want to go? 14's 13's 12's..... Do you want a radical street machine, or is gas mileage a concern. What do you use the car for, most? Will take work on your part thou.
Well i want to run about 13's and its my only car so i have to get desent gas mileage.Thanks people for the information i now have an idea of what i got to do.I was thinking about changing the carb,manifold,heads,cam,and putting 3.73's gears on it.What do yall think?
Old 03-06-2007, 12:38 PM
stepside454's Avatar
I had an 86 GMC Cabballero (same as ElCamino) that ran 13.80s with a very mild 305 with 3.23 gears.
I used KB143 +.030 pistons, with the L-98 Corvette aluminum heads gave me just shy of 10.0:1 compression. I used a Comp cams Extreme energy gring, I forget whitch one, one of the milder ones, I think it was a XE262. it wass all in by 6000 RPMs. I ran a Performer intake, 570 Holley, DUI ignition,Dynomax headers, 2.5" dual exhaust through a pair of catco convertors & Dynomax Turbo mufflers. It was mild enough that it would pull 16" of vacuum at idle, pass IM240 smog. It got horrible MPG however, but it wasnt a daily driver, I wasnt to consened about the MPG. I used a T-350 tranny with a 2200 RPM convertor.
It was very timing sensitive & also even the smallest change in fuel mixture would make big changes for better or worse. John
Old 03-06-2007, 12:53 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
I basically have a canned respose to this question, as it has been asked several times (try a search you'll probaly find some good threads). ANyway, here it is:
If your goal is overal performance, or to just have a quicker car, start from the back forward. First thing maybe gears, then an overdrive trans (which generally have a lower first gear and allow you to run a steeper rear gear more comfortably). Torque converter is a great addition as well. I would choose parts that you think will work well with a larger cube motor later on. That way if you put one in you're good to go. And if you never get to it, you can just run it as is.
You could probably find an entire rear end with posi and just slide it in there for 2-500 bucks (I'm not sure what they're going for for your model/year). Stall converters are anywhere from 150-400 dollars (depending on the trans). A trans in decent shape might run you 200-600 depending on how many they have on hand etc. 1000 dollars will get you going a lot faster if you spend it with the above method than if you throw it at a 305. The heads you'd need to make power are going to cost 6-800 bucks alone, and with no other swap (cam etc) you'd gain maybe 35 horse even with really nice heads.
K
Old 03-06-2007, 12:55 PM
very good point killer...all the engine wont make a differance if you cant get into the power band,smaller engines need to get up on top
Old 03-06-2007, 12:57 PM
Hippie's Avatar
K
Read it, learn it, live it! Excellent advice.
Old 03-06-2007, 01:11 PM
firestone's Avatar
http://teamrfc.gospelcom.net
I agree with killerformula. Beyond that, when you start buying parts for the motor, I recommend buying parts that you can use on a 350 or 400 based motor in the future. I would use headers/intake/cam (especially if it is a roller) that would also work in a larger motor in the future. I would not recommend buying a set of aftermarket 305 heads or getting any head work done on yours (unless you do it yourself) except for springs. If you ever go to another motor, they may will not work due to the small chambers, and the aftermarket options open up greatly when you get away from 305 heads.
Adam
Old 03-06-2007, 01:18 PM
I think its very do--able. What transmission do you have now? Whats your budget and skill level? what performacne parts do you have laying around that you can either use or trade for better ones? Again what head castings are on the motor now? Does it have to pass an emissions test? Visual inspection?
I think it has a 200 trans.I want to get the most horsepower i can with about $1500.I dont have any parts laying around,this is my first project car so im a beginner,but i do have some experiance working on cars,just the basics.Im not sure what head castings are on the car right now,and it just has to pass a visual inspection.
Old 03-06-2007, 01:22 PM
Like Killer said, start at the back, find out what gears you have, probably 3.08s, swap em for 3.23 or 3.42s , change trannys to a 700R4, thats been built put a converter in it. If you still have any money left, put on some small tube headers & free flowing exhaust.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
9" to chevy conversion bigiron Transmission - Rearend 4 10-11-2005 10:32 PM
Help, 1977 Chevy C20 with Rochester Q-jet won't pass smog. Terje Engine 18 07-16-2004 03:14 AM
New Member Introduction - 48 Chevy Rodder 48 Chevy Rodder Hotrodders' Lounge 0 10-20-2001 03:04 AM
