chevy 305h - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2006, 10:01 AM
stoney 81ta's Avatar
chevy 305h
Ihave a chevy 305h in a 81 trans am stock,where can i find info on this motor.Done a google search with no results.Thanks all for your help.
Old 09-02-2006, 02:35 PM
327NUT's Avatar
Start with www.Mortec.com, it will give you all the bore/stroke and casting numbers.
Old 09-02-2006, 03:02 PM
Thanks 327Nut nice info,what i am after is any performance ratings like hp and torque.Have seen vrious specs from 145hp to 175hp also would like to know if the h denotes its high overhead.
Old 09-03-2006, 06:02 PM
Just look up info for a small block Chevy, 267-400 cu in. They are all about the same, a 305 isn't much different than a 350. Except the 350 is better.
Old 09-03-2006, 07:33 PM
Thanks Jake tried that but no help.
Old 09-03-2006, 10:33 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
here's a PAGE that has some good tech tip on the 305.....joe
Old 09-04-2006, 07:04 AM
Thanks Joe
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
9" to chevy conversion bigiron Transmission - Rearend 4 10-11-2005 10:32 PM
36-39 Chevy Sedan frames Rufus_2 General Rodding Tech 5 09-02-2004 12:52 PM
Can you use a 1933 or 1935 Chevy transmission in a 1934 Chevy? mistermuscles Transmission - Rearend 0 07-18-2004 05:40 PM
New Member Introduction - 48 Chevy Rodder 48 Chevy Rodder Hotrodders' Lounge 0 10-20-2001 03:04 AM
