Chevy 305U how to measure vacuum - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-21-2008, 03:04 PM
Absolute beginner
hard start solved
Originally Posted by rack
Hello again,
Finally I measure the compression of my engine.
It is between 110 and 120 psi on different cylinders, engine hot and WOT.
I also changed the oil. It was very dirty with a lot of carbon deposits in it. I put 4 liters of oil in and the oil level is between add and full marks on deep stick. It was overfilled with oil because I drained more than 5 liters from it. Now the engine does not smoke much but I think I have problem with carburetor adjustment.
The problem is that now it is very hard to start the engine when it is cold
When I open chock plate it starts much easier. I think the mixture is very rich as it has very strong gasoline smell. is this connected with idle mixture somehow?
Thanks a lot.
Ivo
Hello again,
I find out what the problem was. The fast idle screw was on the first step on the cam, not on the second one as recommended. I corrected this and now the engine starts fine. I wonder how the fast idle screw could go there by itself
I don't see any way how to keep it in the right position
Thanks again
Ivo
PS here are some pics of my monte and my trabant
ID:	31382   Click image for larger version
  #17 (permalink)
Old 07-21-2008, 04:59 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
I see that parking must not be an issue for you. The Trabant fits nicely on the hood of the Monte, doesn't it? Ha, Ha
It's good to see other cars like mine, especially the world over. I own two '78s, and an '80 in that body style generation--however none of mine currently run... .
In a while, Chet.
P.S. Is that a bra hanging from the right rear tire?????
  #18 (permalink)
Old 07-21-2008, 05:18 PM
Absolute beginner
I did not noticed it looks alike
Unfortunately not any bras
It is just a rag I tried to seal broken exhaust with
  #19 (permalink)
Old 07-21-2008, 08:16 PM
schnitz's Avatar
Wiki Edits: 54
Uh huh..... Sure it is......
In a while, Chet.
  #20 (permalink)
Old 07-22-2008, 10:58 AM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
[QUOTE=rack] I wonder how the fast idle screw could go there by itself
I don't see any way how to keep it in the right position :[QUOTE]
There should be a spring that the screw goes thru to keep pressure in the screw to keep it from backing out.
R
"SlowRide66"
"Illegitimis non carborundum"
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 07:43 PM
Where is manifold vacuum port on Quadrajet 4mv? dr-data Engine 10 12-13-2005 05:41 PM
Vacuum Trouble - Chevy 350 Fragzem Engine 2 11-08-2003 11:37 PM
Chevy 454 PCV and Vacuum question rakundig Engine 7 10-29-2003 09:33 PM
Chevy 350 vacuum tree color code Jag Daddy Engine 1 03-29-2003 03:21 AM
