Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy 307 Build
Thread: Chevy 307 Build
Old 04-28-2013, 02:50 PM
tresi tresi is offline
I understand using what you've got on hand but 400 rods? are you putting in a 400 crank as well? If you're porting the heads might as well open them up to 1.94 valves. If you will be mixing up parts in the rotating assy you will need to balance it. Do a mock up assemblely before you mill the block.
