Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy 307 Build
Thread: Chevy 307 Build
Old 04-28-2013, 03:35 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
Wiki Edits: 9
Sounds like if you cut the block .025 you'll be at zero deck with pistons. The 416, 305 heads have 56-58 cc chambers, (flowing about 175 cfm), I figure your parts list will give you 11.40 scr, high for pump gas.
I understand those heads are prone to crack, have them checked out. Keep in mind your quench as well.
Semper Fi
