Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy 307 Build
Thread: Chevy 307 Build
  #28 (permalink)
Old 04-28-2013, 09:09 PM
ss307 ss307 is offline
Originally Posted by 68NovaSS View Post
That's what machinists do. Do you know if the block and/or heads have been resurfaced in the past? Have you cc'd the heads? They should be 56 - 58 cc's if not cut.
The heads have been resurfaced. No I havent cc'd them. Heres the question now-Do I use flat tops and mill the block .025 to have a maximum of 9.8:1 ratio. Or do I leave the block alone and use 4cc domes(these pistons are over $300 more). Compression would be at or a little over 11:1. Would pump gas do the job?
