Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy 307 Build
Thread: Chevy 307 Build
  #37 (permalink)
Old 05-02-2013, 08:38 AM
ap72 ap72 is offline
Banned
Originally Posted by naphtali5725 View Post
Hello DoubleVision,
Can you take a 350 4 bolt block and put in a 307 crank and 5.7" rods, That will basically make a 327 correct?
In doing so what pistons should be used with edelbrock heads to get max comp ratio for pump gas, flat tops?
What would the best distance be in the hole for the pistons? zero?
Kind regards
You CAN go this route, but why?
To be different you may as well just go for the Chevy 302, for power there's no reason to not go with at least a 350. A well prepped mostly stock 350 short block can take more abuse than people realize, with sbc's the limiting factor is usually cam and valvetrain, NOT stroke.
