Chevy 307 Loss of Power - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2010, 03:40 PM
I have a 1970 Chevy C-10 with a 307, 3 on the tree, stock 2 bbl Rochester carb. I am experiencing an intermediate loss of power that seems to occur under a load at higher rpm (long hill, running at 65-70 mph), or when shifting into 2nd gear on an incline. Seems to only occur when the engine is hot, running for more than 30 minutes.
Carb was rebuilt about 3 years ago, points, plugs timing all seem fine. Only modification to the engine is a dual exhaust, but I left the stock manifolds on.
Any ideas?
Old 07-19-2010, 04:27 PM
maybe bit of vapor lock
Old 07-19-2010, 04:32 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
How many miles you got on it? Still running the stock distributer i guess. Have you thought about a up-grade on the distributer?
You need to put a light on it and see where the timing is at. JMO
Also could be a week fuel-pump. I had one do the same thing on a hill or slight incline or under a load turned out to be the fuel-pump.
Cole
Old 07-20-2010, 06:26 AM
67k miles, still running stock distributor, timing is OK.
I replaced the fuel pump, probably 10 years/10K miles ago. Shouldn't they last longet than that?
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
307 Chevy build-up JAKE 68 GMC Engine 18 01-26-2012 11:37 AM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
307 Chevy build-up JAKE 68 GMC Engine 2 09-24-2006 07:19 AM
power steering 48 chevy coupe ksm Suspension - Brakes - Steering 1 06-18-2003 08:45 AM
