Chevy 3100 steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2013, 03:23 PM
Chevy 3100 steering
Hello
I have put in an 350 engine in my 54 3100 pick up. no i have the Problem that the original steeringbox doesn`t fit anymore. does someone have an Idee how or wich steeringbox i can put in. i still have the original front Axle.
Thanks a lot for help
Old 06-24-2013, 03:01 PM
There some pictures
ID:	75150   Click image for larger version
Old 06-25-2013, 11:58 AM
ogre's Avatar
the 'Duracell Project'
change your manifolds and offset your motor to the pass side one inch should work
look here for many builds using AD trucks and sbc motors 67-72chevytrucks.com
The Following User Says Thank You to ogre For This Useful Post:
swiss54chevy (06-26-2013)
Old 06-25-2013, 02:11 PM
Yep, this swap has been done for years, use Ram Horns to get more clearance and move the box over. The pitman arm will need to be bent down under the box a little. I had an old frame once when I did one and cut the chunk from the frame where the box mounted and simply welded that to the side if the frame after a little trimming and the box bolted right one of course. At little trimming to the firewall, moving the column over at the top makes the most sense to me so the steering wheel isn't crooked.
The Following User Says Thank You to MARTINSR For This Useful Post:
1957 Chevrolet 3100 Steering Column to DD joint help. Xephius Suspension - Brakes - Steering 0 02-17-2013 07:28 PM
54 Chevy 3100 Martinpdickinson Introduce Yourself 1 11-09-2012 04:45 PM
54 chevy 3100 54chevyinaz Introduce Yourself 3 08-07-2011 07:09 AM
54 chevy 3100 54chevyinaz Suspension - Brakes - Steering 1 08-06-2011 01:46 PM
51 chevy 3100 raven51 Transmission - Rearend 4 03-23-2006 05:17 AM
