Chevy 3100 stock rear end HP capability - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2011, 07:33 AM
Hey fellas,
My truck has the inline 216 in it and I am trying to plan out what to do with the engine, transmission, driveline, and rear end.
I know I am updating the transmission and I am leaning towards swapping in a 235 inline 6 or a small v8 such as the 283. The 216 just has very little power. I'm not intrerested in extreme power, just would like to be able to cruise the highway comfortably.
So my question is, what will the stock rear end handle in the 3100? If the stock rear end will handle the 283 or 327 I may keep it in place.
I know it will handle the 235 but not sure about the 283 or 327.
Thanks,
Shep
Old 06-28-2011, 12:26 PM
HP doesnt break axles...Torque does.
That being said, if you're going to drive like my Drivers Ed teacher wanted us to...It'll be fine with a mild 283 or 327, especially if you're using an automatic.
Old 06-28-2011, 01:45 PM
Wiki Edits: 49
If your truck has the original rear end with the original gearing you'll probably want to swap it out anyway. The 1/2 ton trucks had a torque tube driveshaft which isn't compatible with a modern transmission and the stock gearing is way to high for comfortable highway speeds. These trucks were designed for dirt roads and normal cruising speeds of around 40 mph. Out on the highway that little 216 would be screaming at 60... if you could get going that fast.
So... the solution is a mid 70's Camaro or Firebird 10 bolt rear end. They're the correct width, they're plentiful, have decent gearing, and if you don't want a posi it will be pretty inexpensive. It will also be compatible with whatever modern GM trans you might want to use.
Good luck.
Centerline
HotRodsAndHemis.com
The most important things you learn are those things you learn AFTER you know it all. -- Chip Foose
rear differential for a 51 chevy 3100 50bowTie Transmission - Rearend 3 06-18-2011 11:51 AM
stock g body rear end capability!? djohnson308 Transmission - Rearend 5 06-12-2011 06:31 AM
IFS Mustang II for my 53 Chev 3100 W/stock ride hight? zachscc Suspension - Brakes - Steering 1 02-07-2009 08:36 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
Corvette rear end in a 51 Chevy p/u 3100 oldford Transmission - Rearend 2 04-30-2002 12:33 PM
