| Sponsored Links |
Register now (free) or login to remove ads |
#2
327 are already screamer, add a good 4 barrel 650, headers and intake, and some 373 gears |
#3
high- horsepower ,yes they will turn some rpms need a solid foundation quality crank rods and pistons I got one two months ago but cylinder cracked and would need sleeve. rod bolts came loose at 7000 rpm yeezh- motor became a boat anchor |
#4
Good Rod to stroke Ratio
plus a 307 Chevy bore it to .060 and it is 327 I had a 307 that would run circles around the 305 I had in another car |
#8
Haha, ya got a ways more to go to make 327 ! |
#9
The same principles apply to the 327 as does any other engine. First determine the operating range of the engine, and build a COMBO to match. This means matching the flow patterns of the heads to that of the cam, intake, etc.
A friend of mine has a 327 in his El Camino. He has 4.11 gears and a th-350 trans. He is running some old dart heads, a Edelbrock RPM cam and intake, and I believe a 650 carb and the thing is mean. Very powerful and that big car moves!
Bringing history and technology together. |
#11
do u have a 327 or 307 block or you were just thinking about finding one? a 302 is a high reving son of a gun too. |
#12
Chevy 327
It is a 1964 327 block .030 over (331). It has a Weiand tunnel ram with 2 edelbrock 600's. The gears are 4:56 with a th350 tranny in an 87 Firebird. It has trw pistons, crane cam, pink rods and a cast crank, alsoa msd dist. Just looking to get above 6400 rpm's.She starts floating at 6400, so my shift point is 6200. Oh yea, I am old enough to remember the 327,s, 348,s and the 409's.just trying to build stronger with the 327. thanks for all the replys.
#14
4:56 with an automatic? Yikes. If you are going stronger I think you are going backwards. I am a 60s GM muscle car fan and love small blocks. You are taking a techology car that would probably kill the 327 if you put the same efforts into the late model motor. There is a reason that these little Hondas with big fart tubes on the back (my new favorite term) are killing hemi cudas. So if you are thinking "stronger" then I think you should rethink. Just my opinion of course. Last edited by rrmccabe : 09-01-2005 at 04:00 PM. |
#15
Chevy 327
I know the 4:56's are high, would prefer 4:11's, but these were in the car when i got it. It is strictly for the strip though. I like your terminology though about the honda's, that was cute. I value evey bodies opinion too.
| Thread Tools | Search this Thread |
| Similar Threads for: "Chevy 327" | ||||
| proper camshaft for a 327 chevy??? | straycat60 | Engine | 23 | 06-14-2011 06:19 AM |
| Chevy 327 with a 3.48" stroke??? | Chevelle Crazy | Engine | 9 | 01-12-2007 11:52 AM |
| rebuilt chevy 327 small block wont fire | 78 Nova | Engine | 3 | 01-12-2006 06:54 AM |
| Chevy 327 Engine # | Junior's67 | Hotrodding Basics | 5 | 11-14-2003 02:59 PM |
| Chevy 327 Cam/Lifter Change | Ted's37 | Engine | 4 | 04-23-2003 08:23 PM |
