Chevy 327 build recommendations - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-25-2013, 12:31 AM
So I've decided that I will attempt to rebuild the motor myself and send the block to a machine shop for work if I need to. The HOA can go worry about crime or something else. This way I can afford better parts and learn a lot.
Here are the parts I'm considering right now:
Heads: http://www.summitracing.com/parts/rhs-12052
Head Assembly Kit:
RHS 12987-01 Cylinder Head Assembly Kit with Dual Valve Springs and 2.020"/1.600" Valves for Small Block Chevy : Amazon.com : Automotive RHS 12987-01 Cylinder Head Assembly Kit with Dual Valve Springs and 2.020"/1.600" Valves for Small Block Chevy : Amazon.com : Automotive
Cam/lifters: http://www.summitracing.com/parts/hrs-cl113215-10
Intake: Edelbrock Performer EPS (not the RPM)
Carb: sticking with my Holley vac secondary 600cfm
Rockers: ???
Pushrods: ???
I've not completely figured out the timing chain/button/thrust washer deal yet.
I should be looking for a composite gear for my distributor right? I've read that it's suggested that a channel be milled or filed into the bottom band on the distributor shaft to provide oil to the gears. Is this necessary for all applications?
Is it necessary to remove the inner valve spring during break in?
Should I replace my crank/rods/pistons even if they look ok? If my pistons are dished, I'd like to go with flat tops.
What do you think about all this? Any suggestions on changes or any parts is greatly appreciated. Also, links to step by step (photos preferred) on how to assemble anything would be helpful. My books don't go over retrofit roller cams.
Thanks,
Wilson
  #17 (permalink)
Old 06-25-2013, 02:32 AM
vinniekq2's Avatar
so now you are just looking for small to moderate improvements for your engine?
  #18 (permalink)
Old 06-25-2013, 03:58 AM
That was the plan the whole time. I was never going for 450 hp
  #19 (permalink)
Old 06-25-2013, 11:12 AM
vinniekq2's Avatar
spend some money on a good carb and a good roller cam and be done
327, build, chevy, combo
327 Help & Recommendations SoCa06Z Engine 48 06-21-2012 03:47 PM
rear end gear recommendations for 327? chevyrally68 Transmission - Rearend 6 09-28-2011 09:26 PM
454 build specs, any recommendations? Omer Engine 3 08-18-2011 09:34 PM
Best combinatioWant to build a Chevy 327 300 H.P. from scratch. Where do I start? 56Bowtie Engine 7 04-18-2011 03:03 PM
327 Chevy build--suggestions please! TooSlow Engine 8 05-09-2007 06:29 AM
