Chevy 327 camshaft-"300" and L79 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2007, 12:41 AM
What exactly is the 1966 Chevy 327 "300" Camshaft. Is it the same as the L79? Im rebuilding a 1966 Chevy 327 and i heard the "300" horsepower cam is the best. The engine is bored 0.060" over. I have Camel-hump heads w/ 1.94/1.60 valves. I'm 14 and this is my first rebuild. Any help would be nice.
Im using flat-top Silv-O-Lite hypereutic pistons w/ two valve reliefs.
Old 06-23-2007, 01:01 AM
JeffB's Avatar
L-79 Cam
The L-79 cam was the 350HP 327 cam.I have used these on several small blocks they are a great street cam.If you want a little more bang for the buck,this is available from Summit Racing part # SUM-K 1105 cam & lifters for $62.99.Read up on the posts here about cam break-in oils some oils don't have the additives they used to due to the Feds,maybe do a search on Shell Rotella.Good Luck!
Old 06-23-2007, 05:24 AM
Cool! good to hear another 14 year old is building an old 327. My Son built one at the same age a few years back: Dalton's Ride
We used a solid lifter cam out of the Comp's Extreme energy line, XE268S I believe and it worked well with his combination. Your piston selection, head gasket thickness, deck height, rpm range, fuel, vehicle weight, transmission, and rear end gear ratio will all play into what cam is right for you----so if you give us some more details you'll probably get some good information on cam selection.
Those Summit cams are hard to beat when you're on a budget and they've been proven to make some decent power-better than the old oem grinds.
Old 06-23-2007, 07:15 AM
Hippie's Avatar
Last journal entry: HEI comparison.
The 300HP cam is very mild and is basically the same cam used in most 60's and 70's standard performance small blocks. Good daily driver cam for heavy cars with automatics and high gears. The L-79 as stated above is the old 327/350 HP cam. It has a bit of a lopey idle and works best in lighter cars with 4 speeds or a high stall converter and lower gears. Great "drive in cruiser" cam in a smaller engine. They are both old tech though and unless you just have to have an authentic old school cam there are hundreds of better cams. I agree on the Summit cams being a great bang for the buck. We have used a few of the 1102 and 1103 grinds and have been very happy with them. A friend has the 1103 in his '64 Impala SS with a stock 327/250 HP, PG and 3.36 gears and it works very well. Decent low end, strong mid range and pulls strong past 5,000 and even with the Glide and tall gears it pulls hard from a dead stop. No "drive in" idle though just a healthy "burble" to the exhaust note.
Old 06-23-2007, 11:54 AM
DoubleVision's Avatar
Since both cams indeed do work, but are based on old technology, I`d use something else, even so to each his own. The summit cams are okay also. But if your looking for a cam with a lopey idle, but still has excellant street manners than the the comp 268H magnum is for you, it`s a rather small cam, has great low and mid range power, will work with a stock converter. If I recall correctly the specs are .218 Duration @.050 and .454 lift. Since your 327 is a smaller cubic incher than a 350, and you wanted to feel safer with the low end, you could advance the cam 4 degrees at the timing chain. My hats off to you for building a 327, these are great small blocks, give it some gears and tune it accordingly, and it`ll surprise a few 350`s.
Old 06-23-2007, 12:09 PM
Yes Bird I was aware of the 4 degree advance ground in, however, It can still be advanced more and likely isn`t going to really hurt anything. No harm no foul here, but I was just recommending a cam of my opinion that would give good street manners and still lope, I wasn`t going to get technical about it. Like I`d already said dude, to each his own.
Old 06-23-2007, 12:54 PM
larryblack's Avatar
Certified Lead Foot
That 4* of ground in advance on the cam is to compensate for the 4* of retard ground into most modern crank shafts.
The 327 crank will not have this retard so installing the cam essentially advances the cam. I have seen numerous 327's built with the L79 cam using headers, dual plane intake, vacuum secondary carbs with 3:42 or 3:73 gears get 15 mph around town, and 19+ on the highway in early camaros.
It is a forgiving cam. Using any 268 type cam from any mfgr will be just about the same, only the ramps sometimes need better springs.
Old 06-23-2007, 01:30 PM
larryblack's Avatar
Certified Lead Foot
[QUOTE=F-BIRD'88]
There is no such thing as a crankshaft made or ground with 4 degrees of retard.
[QUOTE]
You obviously have never taken a steel 350 crank from a 69 or 70 model engine and placed it side by side with a cast smog motor crank and seen the difference of where the key way was ground. That was how the crank was retarded the cam 4* with no other mods.
I had instructions from both Crane and Comp Cams about this very retarded key way when installing cams in the 80's. I usually put the cam up 4* using the slot on the crank sprocket and got a 2* advance out of it.
Old 03-31-2013, 05:36 PM
327 cam
I have a problem . I've built sbc for years and never saw this . I have a (300) HP 327 in a '75 Monza with a Super T-10 and a 12 bolt rear . I'm retired and needed a toy for the strip . I installed a Comp cam, intake .500 and ex .488 and when turn it by hand it locks up when the ex gets close to max lift . I've use cams bigger than this in a 350 and 370 HP block but those had dome pistons . And maybe deeper valve cuts ? This has flattops with 4 eyebrows . Could it be that with this piston my limits are less ? The factory listed the 300 cam lift at about .360 ? If I can't use it, I was thinking of installing a .390/.410 . I just wanted a little more power and the latest cams are better . These Pro Comp alum heads have a 64 CC chamber but I don't see where that should hurt . The chamber is cocked a little compared to stock, and I wonder if the ex is hitting the side of the chamber . They weren't designed for a '68 engine . I hate to pull the heads but I'd rather change cams . I'm not going to cut the pistons . Too much work . Let me know what you think . Thanks .
Old 04-01-2013, 10:59 AM
The L79 is a great cam with great street manners. This is the Crane Vintage Muscle version.
331 CI, pump-friendly 9.5:1 CR
K&N 14"x4" air filter, Corvette drop base and lid
Holley 600 dp, choke horn milled and blended, Primary - 69, Secondary 74, Squirters - 21
1/2" Aluminum open spacer port matched to manifold, exterior polished
Edelbrock Performer RPM intake manifold, port matched, exterior polished with all extraneous castings and lettering removed
Homemade lifter valley splash shield to keep hot oil off manifold bottom
Manifold heat riser crossover blocked
Camel hump 1.94/1.50 heads hogged out to 2.02/1.60, pocket ported, port matched, pump-friendly hardened seats, 3-angle valve job
Cylinder bores clearanced to unshroud the valves
Comp Cams 1.52:1 roller-tip rockers
Crane Cam Vintage Muscle 327/350 hp cam, 222 degrees @ 0.05, 0.447" lift (with 1.50 rockers)
Doug Thorley headers, dechromed and ceramic-coated
2.5" mandral-bent exhaust (including tips), 2" cross-over just before rear axle
DynoMax stainless Ultra Flow mufflers
Millerspeed 1-1/2 Gilmer under drive belt drive system
Mallory Hyfire IV CD ignition box triggered off Accel points
Mallory high voltage chrome coil
Mallory spiral-wound coil wire
Mallory solid copper plug wires, ends soldered to wires
Champion plugs
37 degrees total ignition advance
Carter high volume fuel pump
Melling high volume oil pump
Open breathers
Polished aluminum high flow water pump
160-degree thermostat
Flex fan with polished aluminum spacer
Polished aluminum one-wire 100 amp alternator
Header Power Bracket
Keisler TKO600 5-Speed
Hurst shifter
3.70:1 positraction with Big Block yokes
225/60/15 Firestone Firehawk SZ50s on 7-wide Western 30-spoke Turbine Wheels
anyone have the cam specs....... mark anderson Engine 5 12-07-2003 02:00 PM
