Chevy 327 - recommend spark plug wires - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2011, 02:50 PM
KENMO's Avatar
St Louis Blues fan....
Hi...
My 60 Vette has a 327 with the Chevy ram horn exhaust manifolds and a MSD Street Fire HEI distributor... I'm not pleased with the plug wires I purchased from Canadian Tire. They work fine but just don't look right. Some plug wires are a little too long and others are a little too short so getting the wire routing to look ok is a bit of a task...
Can anyone recommend a good set of assembled wires? I don't care much for the universal wires that you must cut to length as I never have any luck with them...
Cheers & many thanks...
Ken
Old 07-21-2011, 02:57 PM
327 / 350 hp's Avatar
327 wires
Hi ken, i had same problem with a 327 a while ago..... I had to custom fit the wires to go under the rams horns,, they attached with looms on side of block. Good Luck jim
Old 07-21-2011, 04:50 PM
sqzbox's Avatar
My pipes are my music
Pro Comp has wires designed for over the valve covers or under the exhaust manifolds. Check into them. I bought a set for over the covers that work very well for my 350. I imagine the under's should work for you. The ones I bought are 10mm HP spiral wound and were very reasonably priced from KMJ performance --------------------- Never mind, you'll have to look somewhere else. KMJ has changed their web site and it sucks now. Their pushing moroso parts on Ebay. Sorry.
Old 07-21-2011, 05:21 PM
KENMO's Avatar
Thanks... Just checked Jegs & SummitRacing and they don't carry their wires...
Cheers
Old 07-21-2011, 07:20 PM
sqzbox's Avatar
Cheers
www.procompelectronics.com should work for you. or, google pro comp spark plug wires. and click on the first web site on the menu. Good luck.
Old 07-21-2011, 10:09 PM
RippinRon's Avatar
Why don't you invest in a good crimper and make them any length you want?
Old 07-22-2011, 02:02 AM
JeffB's Avatar
A couple of weeks ago KMJ and Skip White both had Pro-Comps(close out special),no more Anyway put Pro-Comp spark plug wires in ebay search and take your pic.
Old 07-22-2011, 05:26 AM
KENMO's Avatar
Can you recommend a good crimper? What price are we talking?
Thanks kindly...
Spark plug wires jumping spark STATUTORY GRAPE Engine 4 10-04-2009 05:14 AM
Spark Plug Wires & MSD KENMO Engine 1 07-23-2009 09:00 AM
Spark plug wires Miller Engine 10 05-23-2007 04:24 AM
spark plug wires oldsF85 Engine 5 03-30-2004 11:00 AM
Spark Plug Wires bg Engine 7 12-26-2002 09:22 PM
