Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy 350-1980 Blazer problems
Old 09-27-2012, 09:50 AM
BlazerMan80 BlazerMan80 is offline
I had adjusted the kickdown, but doing some research on it, I believe I did not do it correctly, I did not open the choke wide open(off position), before opening the throttle wide open. I haven't had a TH350 in a while and did not remember the procedure to a T. If you have a procedure you use please let me know. Thanks for the help.
