Chevy 350 with 292 cam Total timing - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-29-2010, 07:47 AM
how am i suppto tell what my compression ratio is? we had the motor tour apart. bored 60 over with flat top pistons the stock heads been shaved and the guy that put the motor told us to get this cam cause its consitere a rv cam and has alot of low end tourque. but now u guys say about the stall converter i dont really know know, maybe this one is stock. maybe its not. anyway to find out by looking at it i have the dust cover off on the tranny. illl just run the damn thing. if the tranny goes its getting a 4 speed muncie anyway. or a 5 speed
  #17 (permalink)
Old 08-29-2010, 07:50 AM
as for the ad vance canister should i turn it out a little more to get 25 advacnce? its at 23.
  #18 (permalink)
Old 08-29-2010, 09:31 AM
sbchevfreak's Avatar
Licenced Automotive Technician
An RV cam usually has 250-270 degrees adv. duration, and .420-.470 lift. Will work with a stock converter, and has good bottom end. Rpm from 800 to 4000 or so. The cam you have is most definately not an RV cam. It's operating range is from about 3000-6500 rpm. Fbird told it true, to make it work you will need to do some more work.
  #19 (permalink)
Old 08-29-2010, 09:47 AM
yeah you need a 3500 stall, recurve the dist, and the gears id use 3.73's and up depending on what you are useing it for, timing it would do good setting inital timing @ 16, or persay 36 total..
  #20 (permalink)
Old 08-29-2010, 11:32 AM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
You got some build issues here, its all there in the other posts, you should get us more info on the motor but a band-aid can be the HEI dist:
first get the dist out and on a clean bench, get a vacuum gage and a good light, pull the rotor off, you are going to set limits on both the vac advance can and the mech advance travel,,,wanna?
http://www.cranecams.com/pdf/254g.pdf
  #21 (permalink)
Old 08-29-2010, 03:48 PM
ill just run it, it seems to run fine. i aint gunna change the gears has 3o8 gears. to change the gears idd have to change the front to. its a 1985 chevy k10. for some reason i thought the cam i bogught was a rv cam. so what is this cam a top end cam?
  #22 (permalink)
Old 08-29-2010, 03:50 PM
ill probably have someone look at the truck and tune it
  #23 (permalink)
Old 08-29-2010, 04:03 PM
techinspector1's Avatar
Wiki Edits: 326
That may be your best plan. It seems like you are really uninterested in learning how to do it yourself.
  #24 (permalink)
Old 08-29-2010, 04:25 PM
Custom10's Avatar
Yep, 308 and nothing out of the gate, the combo is a bit of a mismatch but don't let it get ya down. The combo just won't pick up the truck like you thought, if you are going to drive it as is then surely get the dist curve/setup figured out at the very least. Expect the guy that tunes it to repeat some of what you have heard here if he knows his onions,,,don't give up on it.
  #25 (permalink)
Old 08-29-2010, 05:03 PM
It aint that i wnat to learn. I know how to do it. but i dont got the cash to take get a stop plate, Can i get one threw summit.? maybe if someone could post a link to the one i need for my msd street fire i will. im going to but the dissy stop on deffinly and time it to what it need to be, Will running it how it is now hurt anything i gotta goo to work and back...., it dont seem that hard to put a dissy stop in. can i do it with the dissy in the truck? or do i gotta take it out. as for the stall. ill have to wait till next summer to get a other stall. so you guys think a 3500 would be good for me. i did some reading today i hurd of people using a 2900 tall too. well if one of you guys could like say what im gunna need to get it tuned right. but as for changing out rearend gears and front end gears thats kind out. unless its not that big of a job. but i have to change the front if i change the back correct to use my 4x4? im sorry if i came across to you guys the wrong way. i dont know nothing about stalls so i figured the one that came with this tranny would be perfect what differnce will a 3500 stall bee from the stock? im not drag racin it just a daily driver. but i want it to have some BALLS too lol. will the 3500 make the engine wind more? my th350 shifts at 4 grand into 3rd gear thats as high as i can get it... probably the timing/ tuning as alot to do with it or is 4 grand about right?
^ LOTS OF QUESTIONS SORRY^^^
  #26 (permalink)
Old 08-29-2010, 05:19 PM
will this work for me? http://www.summitracing.com/parts/CRN-99619-1/
does a stall converter affect top end or just bottom end? like take off?
  #27 (permalink)
Old 08-29-2010, 05:47 PM
Custom10's Avatar
OK so now you want to fix it,,,then remeber the combo I refered to? well you may be lucky cause if you want a driver then a new cam is the easyest solution here. Whoa on the convertor/gears for a bit.
Check out he previous posts and find/figure out the engine DCR and the SCR, this requires you know everything about the machining of the block and the part #'s used etc., get the numbers and in the mean time do the:
HEI, pull it out yourself, it will help you get a handle on things in more ways than one. The crane plate can be dupilcated but if you have time order it, otherwise make your own. Its all one step at a time, remember that you also need to set the mech adv travel and curve springs so this may require further parts/kits. Best to plan ahead and order the parts (maybe 40 bucks). Keep driving it till you get what you need. Mean time try and get the engine info so you can select a cam later, you may not need new conv/gears but the 308's are limiting you,,, reqardless the HEI mods will apply to the new "RV" cam as well. So decide to fix it or have it fixed
  #28 (permalink)
Old 08-29-2010, 06:57 PM
Well i say driver. but not really. this truck is probably only gunna be used in the winter. im a sugar maker. I make maple syrup so the trucks gunna be used in the spring to haul sappp ALOT OF A WEIGHT. and during the winter to go to the woods and haul supplies i need. I orderd the crane limiter plate. you think i need to get a spring kit for it too? like a lighter spring? will the truck run better with this limiter thing?
Get this spring kit? http://www.summitracing.com/parts/SUM-G5212/?rtype=10
Or this http://www.summitracing.com/parts/MSD-8428/?rtype=10
  #29 (permalink)
Old 08-29-2010, 07:39 PM
Custom10's Avatar
Well what we are look'n at is effectively changing the way the HEI does its thing or to optimize it for what it is and what it is being used in. This is not going to be a magic bullet but it will help. Your cold temp starting/idle is most likely going to be horrible unless you can change the cam.
The crane part should be the correct one, this only takes care of the VAC advance part and the can you got should have an internal adjustment screw, allen head thats inside inline with the hose nipple, you will need to tweak this as well.
The mechanical advance limiter parts need to be matched for the dist you have, and I can't say what will work with your HEI. Really you could most likely get by with the weights you have and just use different springs to set the rate of mech advance you need. The other factor that is in question is a mechanical limiter which is not in those kits. What is the model # of the dist? there are a number of ways to set the mech adv limit.
  #30 (permalink)
Old 08-29-2010, 07:52 PM
its a msd street fire hei. part number at summit 8362
help choosing a cam 350 chevy heavymetalhudson Engine 14 07-04-2010 11:30 PM
Stock 350 Chevy Timing Assistance Please. guysnydr Engine 10 05-27-2010 08:26 AM
Chevy 305 With 350 Cam?? CHEVY 64 Engine 17 01-18-2010 08:02 AM
Timing woes on SBC 350 with bigger cam. Brawler Engine 5 09-07-2007 04:33 PM
Longblock Chevy 350 Crate: Cam and Head concerns 360Camaro Engine 18 08-05-2003 03:51 PM
