Chevy 350 with 292 cam Total timing - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 08-29-2010, 07:54 PM
so order a kit with just springs ?
  #32 (permalink)
Old 08-29-2010, 08:38 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
Yeah just get a set of springs for now, this kit comes with some and is low buck, you may use the other parts but can't say right now
http://www.summitracing.com/parts/MRG-929G/?rtype=10
Can you post a close up pic of the dist without the cap and rotor on it? it may be that you just need to add a nut and bolt in there to limit the mech advance, can't be sure cause I don't have the one you do, but it may be very similar to mine and that is all it took, note the robinson head machine scew, this stops the travel.
Once the parts get in take the HEI out, or do it now if the truck can sit. Remove the cap noting what tower on the cap the #1 plug wire is on, mark this inline on the dist base and turn the engine over with the cap off until the rotor is pointing at #1 note yout timing mark on the front damper it should be around TDC, once you get the rotor pointing approx on #1, losen the hold down and pull the dist. Got a vacuum gage?
  #33 (permalink)
Old 08-29-2010, 09:04 PM
yes i have a vacuum gauge
  #34 (permalink)
Old 08-29-2010, 11:07 PM
techinspector1's Avatar
Wiki Edits: 326
Change the cam. This truck will be a turd no matter what you do to is until you CHANGE THE CAM.
  #35 (permalink)
Old 08-30-2010, 07:04 AM
Custom10's Avatar
[QUOTE]
Originally Posted by Custom10
OK so now you want to fix it,,,then remeber the combo I refered to? well you may be lucky cause if you want a driver then a new cam is the easyest solution here. Whoa on the convertor/gears for a bit.
Check out he previous posts and find/figure out the engine DCR and the SCR, this requires you know everything about the machining of the block and the part #'s used etc., get the numbers and in the mean time do the HEI
Yep we all agree except for the OP, your right tech a new cam is the best way to go, but getting some time under the hood and raising up the base from 8 deg BTDC and adding some limiters will help out,
318250
while in there maybe you can pull a valve cover and let us know what the head casting numbers are also what intake, carb, etc. need more info,,, don't know if your still with us here?
  #36 (permalink)
Old 08-30-2010, 04:51 PM
Well heres what iknow off my head. chevy 350 bored 60 over. Seal power flat top pistions. as for heads i know there stock i think but ill try and get the numbers. intake is a edelbrock performer. carb is a 650 holley.
  #37 (permalink)
Old 08-30-2010, 04:58 PM
i gues i should of kept the cam that was in it IN It lol i think it had a 260 duration or somting. it was with a whole chevy 350 sealpower kit. but o well. i dont think ill be changin the cam. engines in the truck now. and i just dont have the time to tear it all apart. ill just trya nad fix what i got. i know what u guys mean it will be a turd with the 308 gears and stuff but im not rich. cant change gears and rear ends. maybe in the furtue? maybe if i would of put a manual in the truck it would have more balls. since of the stall converter. maybe ill change the stall next summer. you guys think ill be okay with with a new converter and with my stock gearS?
  #38 (permalink)
Old 08-30-2010, 04:59 PM
I orderd the spring kit and the advance limiter. is there anything elts ill need for the dissy?
  #39 (permalink)
Old 08-30-2010, 05:44 PM
cool rockin daddy's Avatar
2 x 4? Meet jaw of a stubborn mule. CHANGE THE CAM! What does a new cam and lifters cost? You are gonna spend more than that nickel and diming yourself to death trying to make a mismatched combo run. Listen to what has been said to you. You came here for advice, take it!
  #40 (permalink)
Old 08-30-2010, 05:58 PM
Between the higher stall converter and stiffer rear gears, you'd be ahead to change the gears, or the transmission.
A high stall converter builds in an amount of slip that allows the engine to rev up without forcing the rear wheels to rotate over the brake force restraining them. This is intended to allow the driver to improve his hole shot time by letting the engine move up on it's power curve RPMs without spinning the rear tires over the brakes as I've already said. However, stall is a quirky thing having a lot of variables as to where it will really occur which have to do with engine torque, vehicle weight, rear axle ratio and locking force of the brake system, etc. A converter sold as having a 3000 RPM stall may, or not, actually perform that way in your vehicle. A high stall converter acts like a slipper clutch except that you don't really have much, if any, control over the amount or extent of the slip. What a high stall converter will do on the street is eliminate the creep the vehicle will want to do when stopped for traffic, your foot will get tired from keeping the thing stopped, trust me on this.
One way to recover some lost bottom end for not much effort or cost would be to advance the cam. The Chevy cam uses a pin thru a hole in the gear to establish its timing position. Bushings are sold that fit this hole, with some drilling, that allow the position of the cam relative to the crank to be moved. Advancing the cam recovers bottom end torque but at the cost of some top end. Retarding cam just the opposite. This doesn't change the duration or lift but changes the timing event relative to the crank's position, in this case it closes the intake sooner which recovers some cylinder mixture density, refer back to my early on epistle.
Two other related tricks are to use a fast leakdown lifter like Rhoads, this actually takes some duration off the cam by allowing the plunger to sink against valve spring pressure lowering the net lift and shortening the duration at low RPMs, eventually, the cam will be turning so fast the lifter doesn't have time to react at which point it restores the duration and lift at high RPMs. The problem is they tick like solids. Another solution would be to use a lesser ratio rocker arm, stock being 1.5, most go fast guys change those to 1.6, but you can get 1.4s which would slow the timing events and lower the lift. The engine will react to that as if the cam had less duration bringing the bottom end power up and slicing off some top end. Can't have both with fixed cam timing, but that's a way different story occurring at Indy and European F1 racing, but it's a technology that's coming just not for old SBCs.
The other would be to replace the transmission with a 700R4. These have a real deep low and an overdrive 4th. The deep low (about a ratio more than the TH350 or 400) will launch the vehicle a lot harder, while the OD high and 3.08 rear gear will cruise on few RPMs.
But the simplest and least costly solutions would be to put less cam or stiffer rear gears in there.
Bogie
  #41 (permalink)
Old 08-30-2010, 07:20 PM
what kind of gears? would be best? i wish i could find a truck with the right gears i need and just change the front and rear axels? that would work right. as for a 700r4 thats what it had but it was fried. *** for getting me head out of my but, hand me ur wallet. and time and i will
  #42 (permalink)
Old 08-30-2010, 07:23 PM
now u guys have me wanting to change the gears. what set will work best.? and whats the best way to do it. find a rear and front end that will work? or take the rear end apart and do it my self? isnt it pretty hard to change gears in a rear end.? like dont they have to calibrated and shimmed? and wil lthe stock stall be okay if i change the gears?
  #43 (permalink)
Old 08-30-2010, 07:49 PM
alright here it is, Lets say i put a 3000 stall in and keep the gears i got will it be alot better? cause changing a stall seems easier than changing gears if i cant find a rear end with the right gears. sincei just did a tranny swap. but if it wont be much differnt with a 3000 stall and my stock gears i guess ill have to change the gears too. i have 373 gears in my c10 but its only 2wd if i could find a front one id be set and put the 308 rear end in the c10. well just let me know what u guys think, just cahnge the stall and be OKAY BUT NOT GREAT? or Change the stall and gears and be perfect. id rather just change the stall but let me know what will be okay. im building a RACE machine. just somthing to play in the mud with. and drive around. so if the stall with be okay ill do that but if it will stil be crappy ill have to do the gears too. and what gears would be great to use. id like some gas milage.
  #44 (permalink)
Old 08-30-2010, 08:08 PM
sbchevfreak's Avatar
Licenced Automotive Technician
gas mileage and a 292 cam don't exist in the same world. Especially with the parts mismatch you have. The eaisiest and most cost effective repair to your problem has been mentioned several times. You need a different camshaft. You could go into something like the 270H comp cam, and keep pretty much everything you already have. Cost to you - $100 or so. Converter cost - $300-$500+. Gears - $600 each set, plus shim kits, bearings and seals. The 270H is advertised as the largest cam for stock converter, with 224*@.050", .470" lift. The 3.08 gears would be the smallest gear I would ever use, but not too bad with this camshaft. Slightly choppy idle, not too much though. I think this is the best solution for your issues.
  #45 (permalink)
Old 08-30-2010, 08:22 PM
i already found 1985 k20 wiht a 4 speed manual trans. for 400 bucks. gunna buy if ithe guy still has it.
If i dont use the 4 speed i can use tha axels that have a stiffer gears since its a 3/4 ton truck
help choosing a cam 350 chevy heavymetalhudson Engine 14 07-04-2010 11:30 PM
Stock 350 Chevy Timing Assistance Please. guysnydr Engine 10 05-27-2010 08:26 AM
Chevy 305 With 350 Cam?? CHEVY 64 Engine 17 01-18-2010 08:02 AM
Timing woes on SBC 350 with bigger cam. Brawler Engine 5 09-07-2007 04:33 PM
Longblock Chevy 350 Crate: Cam and Head concerns 360Camaro Engine 18 08-05-2003 03:51 PM
