Chevy 350 with 292 cam Total timing - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 08-31-2010, 07:07 PM
i know i know. you guys say i gotta change the cam. but is the stall you guys were talking about?http://www.summitracing.com/parts/SUM-700350/ will it work?
  #62 (permalink)
Old 09-07-2010, 06:46 PM
Got a 4speed
I picked up a muncie sm465 with 205 transfercase today to put in the truck with the 350. should liven er up some. found a 1ton rear end with 4:10 gears. buyin that to. looks like ill haver her tuned up by this winter.
  #63 (permalink)
Old 10-12-2010, 09:32 PM
Stall
If you dont run a stall speed of at least around 2000 with your setup you will have problems with the engine quiting when put in gear. ( requiring you to idle the engine high to compensate for the rpm drop when its put into gear.) The other reason for the stall is with a larger duration cam you will be making more top end power, thus for a good hard launch your engine needs to be closer to its power band. The stall allows you to reach a higher rpm when the brakes are applied instead of just sitting there and getting louder lol. I have run this exact cam in a customers truck and got by with a stall around 2100. I also ran around 24 degrees of timing (advanced) and this is to be set with no vac. advance hooked up. Goodluck!
  #64 (permalink)
Old 10-13-2010, 07:45 AM
Greg T's Avatar
www.krusinklassics.net
Why is there never enough time or money to do right, but plenty of time and money to do it over? And over? And over?
help choosing a cam 350 chevy heavymetalhudson Engine 14 07-04-2010 11:30 PM
Stock 350 Chevy Timing Assistance Please. guysnydr Engine 10 05-27-2010 08:26 AM
Chevy 305 With 350 Cam?? CHEVY 64 Engine 17 01-18-2010 08:02 AM
Timing woes on SBC 350 with bigger cam. Brawler Engine 5 09-07-2007 04:33 PM
Longblock Chevy 350 Crate: Cam and Head concerns 360Camaro Engine 18 08-05-2003 03:51 PM
