Chevy 350 to 454 conversion... - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2005, 08:05 PM
New Member
I have a 72' chevelle with a 350 and a 3 speed auto in it right now. Working with a limited budget, i was thinking of picking up a cheap early 70's model chevy pickup with a 454 and swapping the two motors and then reselling the truck. What's involved in switching the 454 to my chevelle, and what else would i have to upgrade during the conversion?
Thanks
Scott
Old 05-27-2005, 08:45 PM
roger1's Avatar
Thanks
Scott
It's a bolt in.
You might want to go with a Turbo 400 or a beefed up 350 tranny to handle the extra torque. Your Chevelle would have a Turbo 350 in it.
Old 05-27-2005, 09:38 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
not exactly
The BB uses its own motor mounts. The SB motor mounts will work but the motor will sit up higher in the compartment. If hood clearance is a problem get the BB motor mounts.
The BB also uses a different power steering pump. The SB pump pulley will not line up with the BB pulleys.
Will this work? Chevy 305 Throttle Body w/ Chevy 350 aberg12012 Engine 9 05-07-2004 01:28 AM
350 buick in chevy truck? jrm123180 Engine 7 04-04-2004 12:03 AM
55 chevy 3 on the tree to a SBC 350? mile-hightoyz Transmission - Rearend 8 02-23-2004 10:57 AM
63 Chevy II Turbo 350 conversion chevyhome Transmission - Rearend 1 05-31-2002 04:03 AM
63 Chevy II Turbo 350 conversion chevyhome Transmission - Rearend 0 05-21-2002 10:45 PM
