Chevy 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2006, 07:34 PM
Chevy 350
I have a 1976 350 with a HEI Distributor i'm getting Spark to all cylinders but only 4 are firing #1-4-6-7
Old 10-11-2006, 01:32 AM
Just a suggestion...
Maybe your plug wires are bad or boots not fully engaged on the plugs.
Spray a little water on the wires and try to start it. You should hear the plug wires "crackle" if they are cracked and grounding out to the block. Do this when its dark outside and you should also see the spark jumping to the block.
I found a few bad wires on one of my cars this way.
There's also an off chance that those plugs are so fouled they may not be firing.
Here's a link to the firing order and rotation. Make sure you don't have your wires crossed.
http://boxwrench.net/specs/chevy_sb.htm
Old 10-12-2006, 08:07 PM
May be something's plugged up in one side of the carb. One side of the carb feeds those four cylinders, and the other side feeds the other four. I forget which side feeds which, but follow the intake runners one-at-a-time and you'll see what I mean. A clogged fuel passage in one side could cause a miss with that pattern.
All this is assuming you have a dual-plane intake manifold.
finally finished chevy 350 build redneckrodder Engine 7 05-30-2011 06:03 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 03:45 PM
96 chevy 305 vortec heads on 350 block badriand Engine 6 02-20-2006 07:45 AM
engine cooling specs for 350 4 bolt chevy downunder Introduce Yourself 2 10-02-2004 10:41 PM
85 chevy 305 heads on an 89 TBI chevy 350? jazzguitar Engine 4 11-03-2002 04:11 AM
