Chevy 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2011, 06:56 PM
Chevy 350
HOW DO I FIND OUT WHAT YEAR MY CHEVY 350 ENGINE IS? I GOT IT FROM A FRIEND BUT HE DON'T EVEN REALLY KNOW IF IT'S A 350 BUT, CAME OUT OF A CAR AND THEN PUT IN A TRUCK.
Old 11-10-2011, 07:06 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
You need the block casting number and the block's suffix code. Casting # is on driver's side rear of engine, on the pad at the top where the transmission bolts too. Suffix code is on pass side front of block.. Look in front of pass side head, theres alittle machined pad there, up towards the intake some.
Cole
Old 11-11-2011, 07:56 AM
chevy 350
Thanks, And Where Do I Bring These Numbers Too To Find Out?
Old 11-11-2011, 08:06 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You can do a little leg work yourself here, and if you have problems, come back to the board with numbers.
Moving this to basics.
Semper Fi
Old 11-12-2011, 08:09 AM
chevy 350
THANKS VERY MUCH, IT WAS VERY HELPFUL. NO MORE HE SAY, SHE SAY.
Old 11-12-2011, 08:12 AM
eloc431962's Avatar
Wiki Edits: 37
Right on.
Cole
153 tooth Chevy flywheel in an original '55 Chevy 3 speed stick. Classic Chevy Dave Engine 2 09-17-2010 03:44 PM
newer chevy distributer in older chevy car,what are these four plugs? gearjammer38 Electrical 11 08-09-2010 10:15 AM
Putting a 72' chevy 350 into 1995 chevy silverado that has a 4l80e trans Willbee26 Transmission - Rearend 3 03-28-2010 10:40 PM
chevy camaro vs chevy pickup bolt pattern old fords Transmission - Rearend 2 09-19-2008 06:07 PM
1986 305 chevy vs. 1987 305 chevy new style small block mtinsley Engine 2 08-22-2003 11:55 AM
