chevy 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2012, 09:17 AM
chevy 350
i know this has been talked about alot. I still have a few questions. We installed a new summit cam and lifters 216 duration and a .454/.454 lift cam. I had the intake off and found #1 cylinder at tdc and both lifters down. I adjusted both rockers for that cylinder. Then, went to #8 cylinder and both lifters down and adjusted both rockers. We keep going thru firing order.
I further read from chevy service manual to adjust by finding tdc for #1 and adjusting certain intakes and exhaust valves for that tdc and then rotate crank 360 degrees where the cam gear dot is at 6 oclock and the crank gear dot is at 12 oclock. This should be tdc for #6 cylinder and then adjusting the last eight valves.
Not knowing the correct way we re-adjusted to the service manual way. Would the cam we put in still use the service manual way or should we re-adjust cylinder by cylinder method. If we re-adjust to the cylinder by cylinder method, can we do this with just the valve covers off or do we need to take off the intake agin in order to see the lifters? Thanks for the help
Old 04-09-2012, 09:54 AM
GMCBEAST's Avatar
I have always adjusted them the "service manual" way to get them somewhat adjusted for startup and I have a set of valve covers that I cut the top off of and do final adjustments with motor running. Not the right way I'm sure but it's always worked out good for me as I hate pulling valve covers on and off several times when conventional methods don't work the way they are suppose to. Hope this helps.
Old 04-09-2012, 10:03 AM
Caballerokid's Avatar
Here is a straight forward way to do it.
Valve adjustment proceedure.
Old 04-09-2012, 10:41 AM
chevy 350
I did it he way cabbellerokid explained but, just wondering if the cam we installed is different from the stock version. Someone said on a post that the way cabellerokid explained was for stock cams. They said that performance cams would not be on the downside of the lobe. Does anyone know if the cam we put in is still close enough to stock to not worry about it? summit cam SUM-k0052 kit 216 duration .454/.454 lift
Old 04-09-2012, 11:01 AM
my87Z's Avatar
Veteran/Firefighter-Paramedic
i have always adjusted my valves and set my valve lash by the EO-IC method
http://www.chevyhiperformance.com/te...nfo/index.html
Old 04-09-2012, 11:29 AM
I have done the EO-IC method before as well and it will work just fine. In fact, my cam that I'm running is almost the same as that cam. So either of the two ways will be just fine for you. Good luck
Old 04-09-2012, 12:57 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Everybody has their own preferred way of adjusting valves and now I will share mine too.
When I adjust valves I put one cylinder at TDC compression and check its companion cylinder is at TDC exhaust and both valves are in overlap. I remove all of the spark plugs then place the engine at #1 TDC compression and verify #6 is at TDC exhaust with both valves in overlap. When cylinder #1 is adjusted I roll the engine 90 degrees until #8 is at TDC compression and its companion (#5) is now at TDC exhaust with the valves in overlap. I keep rotating the engine 90 degrees at a time and adjusting the valves until the crank has gone through two complete revolutions and is back at #1 TDC compression.
This way is a little slow but is a little more methodical. You're only adjusting two valves on one cylinder at a time, not 8 valves at a time at different places on the engine.
Old 04-09-2012, 03:37 PM
my87Z's Avatar
Blazin 72, that is pretty much the EO-IC method which pretty much the most preferred method
Old 04-09-2012, 04:14 PM
Blazin72's Avatar
Wiki Edits: 19
You're adjusting the intake valve when the exhaust valve is open on that cylinder, correct? If that's the case then yes it would be close enouhg to be considered similar I suppose.
The difference between Pre 86 chevy 350 and post 86 350's haaslyd Engine 12 12-15-2011 08:37 PM
72 Chevy pickup, 350 with t-350 is the trans slipping Mertz Transmission - Rearend 3 03-20-2011 05:27 PM
DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. Steve-0321 Hotrodding Basics 21 11-26-2007 12:44 AM
Chevy 350/350 cam - poor performance Chuck V Engine 5 08-12-2004 10:23 PM
53 Chevy 350/350 starter won't turn over tm454 Electrical 6 07-15-2003 04:40 AM
