Chevy 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2005, 06:49 PM
Chevy 350
I'am trying to fix a 350 that someone didn't fix for me right.I have a 350 with a 292 dur 501 lift cam,after some time it broke a rocker arm. I replaced it then 30 days later it broke a different one. I was told that i needed to put push rods & rockers for the high lift cam so i did and now i have a broken valve spring.Please tell me what i need to do to fix this the right way.
Old 12-13-2005, 01:05 PM
poncho62's Avatar
Wiki Edits: 5
Sounds like you have something binding........Are they long slot rockers?
Old 12-17-2005, 11:08 AM
Tazz
not all that simple..
If you run a high lift cam you should probably match the lifters, rockers and push rods and maybe new springs to that application. How about contact the people at www.cranecams.com and see if they might help. Tell them your looking at a certain lift cam and want to know what else you need to change.
Tazz
Old 12-17-2005, 07:54 PM
Thanks I will
Old 12-18-2005, 10:57 AM
Tazz
I'm just curious..
Why is carforr answering for beljoe and from the same town in Texas?
Tazz
Old 12-18-2005, 08:34 PM
beljoe/carforr
That's due to my cookies being taken off due to cleaning my computer,I couldn't get back on to Hot Rodders as beljoe so i had to change my log.Sorry but now I'am back as beljoe,Thanks for all the help!
finally finished chevy 350 build redneckrodder Engine 7 05-30-2011 06:03 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 03:45 PM
96 chevy 305 vortec heads on 350 block badriand Engine 6 02-20-2006 07:45 AM
engine cooling specs for 350 4 bolt chevy downunder Introduce Yourself 2 10-02-2004 10:41 PM
85 chevy 305 heads on an 89 TBI chevy 350? jazzguitar Engine 4 11-03-2002 04:11 AM
