Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy 350: Black smoke, is it oil or gas
Old 06-17-2006, 03:14 AM
problem solvers problem solvers is offline
Black smoke in an injected engine was probably a clogged air filter. sounds like it was not a very well maintained engine. i would not purchase it because if you get rid of the sludge that is all thats holding this thing together, and may need extensive vatting and pressure wash to clean up to rebuild. Lots of taper results in poorly maintained chevy small blocks and may not be able to be bored out.
