Chevy 350 bottom end knock - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2011, 07:53 PM
I got a 5.7 liter Vortec engine that had a bottom end knock....I pulled it out & took the oil pan off & found that 1 of the rods had spun a bearing. I then checked the other rods & although the bearings were not spent, they were worn down. Of course the crank isn't perfect but it doesnt have any deep nicks in it either. I was wondering if I could go back w/ stock bearings or if I should use oversize bearings to maintain the correct oil pressure. Can someone please help poor peety???
Old 02-03-2011, 08:39 PM
ericnova72's Avatar
More for Less Racer
Once it has spun a bearing, you can't just put new bearings back in, the journal that has spun will be ruined to the point of tearing up any new bearing you put in there.
The rod is trashed also, at the very least the big end is no longer round and of the correct diameter. The rod may be able to be saved by a machine shop if it isn't too bad, they will resize it to correct tolerances, or if it is too bad it will have to be replaced.
The crank may or may not be savable depending on how bad it is, the crank will have to be reground to the undersize the fully cleans up the surface on the spun journal. Only measurement will determine this, and the correct bearing size.
Old 02-03-2011, 08:50 PM
Thanks for the reply.....will I be able to tell w/ the naked eye that the rod is thrashed??? B/c this doesn't look that bad
Old 02-03-2011, 09:45 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
There's also a good chance all the bearings aren't the same on all journals, I've heard the factory will mix uppers and lowers, in small size increments to achieve clearances due to variances in manufacturing.
Old 02-04-2011, 01:19 AM
ericnova72's Avatar
More for Less Racer
When you say "spun bearing" I take that to mean that the bearing shell has turned(maybe many times) in the rod big end bore. If that has happened you won't be able to tell rod bore size or bore hole roundness by looking at it. A couple thousandths of an inch is all it takes to mess things up. Same with the crank.
Any honest machine shop will tell you that when a bearing spins there is no easy fix. Parts have to be carefully measured(dial bore guage and micrometers good to .0001") and scored parts reworked as necessary.
Old 02-04-2011, 04:58 AM
sqzbox's Avatar
My pipes are my music
I tried that once on a 283. Used some emory cloth, worked the crank and put new same size bearings in it. It only lasted a few months and spun a bearing again. Quick fix is a short time fix.
Knock in my Chevy Bugs Engine 29 01-12-2011 04:08 AM
97 Chevy Vortec 350 knock quadrazer Engine 6 10-22-2009 06:14 PM
Chevy 350 knock driver side? Help jimenezaldo Engine 18 09-01-2005 04:38 PM
Help!!! Knock, Knock, Knock coming from tranny 70bird Transmission - Rearend 1 05-06-2004 12:30 AM
some sort of bottom end knock?? v8s10 Engine 3 07-14-2003 05:39 PM
