Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - chevy 350 build help
Old 06-22-2011, 09:32 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Originally Posted by jimang
where do i start to do this right.
Disassemble the motor and clean it thoroughly, just like you were doing a new build. The shrapnel from the roached cam will begin chewing away at new parts as soon as you fire the motor again. While you have it all down, you can do some measuring and we can determine your static compression ratio and the best cam to use.
We can also help to eliminate any more roached cams by following these tips and tricks upon assembly....
http://www.crankshaftcoalition.com/w...ips_and_tricks
