Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - chevy 350 build help
Old 06-22-2011, 09:54 PM
jimang jimang is offline
hello, sorry the summit cam just didn't do anything for the car and the comp cam just sound good looked bad when taking off. is there a place i can find a easy understandable way to do this sat. compression ratio. i got cam out can i figure it out at this point or will i need a compression for plug with motor running. this is the whole part i am not getting. as for setting lash did by the book turning over setting one at a time, just had to of messed up some where. will learn one way or other. i tried to set the ones the was not moving that much and nothing, lifters are ok little wear on bottom of the not much,when i took valve cover off i put finger in oil in lower bottom corner of heads and under the oil looked like sliver fine fine sparkle metal. just need to know how to do first step, again thank you for your help
