Chevy 350 cam question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2010, 04:57 PM
I am building a small block 350 and am wondering what holds the cam shaft in place? I am use to fords and pontiacs where there is a retaining plate that holds it there. can someone please help me!!!!!!
Old 07-11-2010, 05:02 PM
Check your spark plug gaps
when you first come to www.hotrodders.com there is a search feature that can be used, I know you didn't search because I had this same question about a month ago and just searched through old posts. It is the angle of the lifters or the way the cam is ground that pushed the cam to the back of the engine. Use the search feature
Old 07-11-2010, 10:45 PM
327NUT's Avatar
K5, there is no retaining plate on the non-roller sbc, basically a "tight" cam chain and gear keep it aligned. For very high perf. some builders install a nylon/poly cam button at the nose of the cam that kisses the front cover if the cam tries to walk forward.
350 Chevy, Head and Timing question. monzter Engine 7 09-10-2009 06:52 AM
chevy 350 cam gear symbols? sparkyct55 Engine 1 02-08-2009 09:06 PM
Need Help FAST!!!!!!!!!! millertime85 Engine 14 06-25-2008 07:01 PM
350 Cam Question chevycamarors Engine 1 11-04-2007 05:48 AM
Is this a good cam for a sb 350 chevy? TonyMac Engine 3 03-27-2004 08:12 AM
