Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy 350 cracked starter mounting hole w pics
Old 12-07-2004, 07:27 AM
rifraf's Avatar
rifraf rifraf is offline
Some things to consider,they make standard and metric bolts and starters,do you have the right ones to match your starter? Next,I couldn't tell by the photos,but do you have 3 bolt holes on the block? If so,I would use a 3 bolt nose,I think they came on the late 60s chev trucks,they were not aluminum,use two factory bolts in the good holes to insure proper line up,then use a high grade stud and bottom it out in the hole to get all the thread you can for the third,then put a lock nut on it,just an idea. After all that,get the brace.
