Chevy 350 Crankshaft bolt removal
I'm trying to break loose the crankshaft bolt on my 350 and all I end up doing is turning the engine over. I have a TH350 automatic, so I can't use the transmission to hold the crank in place. The three outer bolts came out without any problem, but the large one in the center won't break loose.
This Goodwrench engine only has about 12k miles on it, and I don't think the crankshaft bolt is unusually tight. I don't remember what I torqued it too when I installed the accessories, but I probably used the recommended torque from my repair manual. I tried using the drive belts to hold the pulley while I loosened the bolt, but couldn't get enough leverage. I also tried to figure out a way to use the three outer bolt holes in the pulley to hold it while I loosened the large bolt, but the deep dish of the accessory pulley gets in the way. Any simple suggestions for breaking the bolt loose? I'd rather not rent an impact wrench just to break one bolt loose. Thanks, Bruce |
Have you tried the poor boys impact method?
Pretty much just get a breakover bar with the right socket on it, and instead of pushing/pulling on it to get it to go. Start hitting on the breaker bar with your hand or a hammer. Usually this will jar a bolt loose and make it easier, plus its usually the steady force that will twist a bolt off to. Brad |
Sounds like a good idea, but I do worry about putting the ratchet through the radiator if everything slips the wrong way.
Would I ground out the coil, or just pull the power lead to the HEI? On a Ford its fairly easy to put a remote starter on the solenoid and bump it over with the ignition off, but on my Chevy ('75 vintage) all the terminal connections are down on the starter. Bruce |
Impact works excellent also, but if you don't have an impact then this is the next best thing. Pulling the power source to the ignition would be good, but either will work. Also make sure that you overlap the frame by a good margin by possibly using a short length of pipe or something on the ratchet. Bump the engine before to make sure that you will be positioning the handle properly, then make sure the person bumping the starter just uses little hits. As soon as it breaks loose then just back the bolt out normally. I also like to lay the ratchet on top of the frame rail where the pressure goes down because if it does slip off there's no chance of it hitting anything. Once you try this you'll see just how easy it works.
Also, I know that Chevy and Pontiac will loosen the bolt when the starter is bumped, not familar which way other brands spin - so other brands just need to check the rotation before hooking up the socket. |
I finally took off the flywheel cover and clamped vice grips on the edge of the flexplate. My son broke the bolt loose while I held the vice grips braced up against the edge of the transmission case, and it worked without a problem.
Thanks for the help. Bruce |
If the motor and/or the oil pan is removed you can put a piece of plywood inbetween the conecting rods and the block and loosen the bolt that way.
| DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. | Steve-0321 | Hotrodding Basics | 21 | 11-26-2007 12:44 AM |
| 10 bolt to 14 bolt rear-end conversion in 96 1/2 ton chevy 4X4??? | tommytempest | Transmission - Rearend | 14 | 05-09-2007 08:19 PM |
| Engine build ideas | Rug | Engine | 23 | 12-25-2006 01:39 PM |
| Buick 350 or Chevy 350 | 72Skylark | Engine | 21 | 02-02-2006 02:10 PM |
| Turbocharging a 350 chevy | radracer43 | Engine | 4 | 09-25-2005 07:30 PM |
