Chevy 350 deck height question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2009, 07:34 PM
Recently picked up a 350 block that's bored / sleeved .030. The left bank of the deck has some rust pitting near the 1st cyl and near the water jacket.
My best check says I'll need .020 removed to be safe, my question is would that be too much? Using a stock crank from an 80 model 350 and stock rods / pistons.
Haven't had the crank or anything in yet, do I need to put them in and check the height (seems not all 350's are exactly the same).
What options do I have as opposed to making the block worthless?
Thanks in advance!
Old 12-08-2009, 10:04 PM
DoubleVision's Avatar
.020 is not a problem. After decking and cleaning, throw the crank in and a few pistons and check the distance, You`ll likely come out around .005 in the hole or so depending. Then get the correct thickness head gasket to get a good quench distance.
Old 12-09-2009, 07:20 AM
Thanks Double...
What would be a good quench so I'll know which gasket to choose after measuring?
Old 12-09-2009, 08:08 AM
Banned
Originally Posted by skynyrdcat
Thanks Double...
in most cases .040" is just right.
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
chevy 350 mechanical fuel pump question usmcsawgunner Engine 2 02-05-2009 01:52 AM
350 Chevy Oil Filter Adpater question plthomp Hotrodding Basics 7 01-15-2007 11:19 AM
350 Chevy Starting question ThumperCR Engine 5 10-31-2004 10:37 PM
Help!!! Chevy 350 Troubleshooting Question 72 chevy elcamino Engine 5 10-19-2003 08:28 PM
